2023 '94 3.0 Rebuild Start
Old Dec 12, 2023 | 06:03 PM
Rosespud209's Avatar
I've had this '94 3.0 since I was 15. Now that I finally have time and money, I'm starting to tackle a long list of to-do's, needs, and wants to the rig lol
*more pictures below
2023 List of Projects Finished:
Timing Belt
Water Pump
Tstat
Temperature switch and sensor were replaced Couldn’t believe the sensor was corroded and hanging on by a thread)
HPS coolant heater lines
Vacuum lines
Valve cover gaskets (chased all header bolt threads)
Plenum gasket
PCV valve
Throttle body gasket
TPS and adjustment
LCEngineering H4 conversion
Napa brake rotors & pads
Wheel bearings repacked
Couple of rusted and broken wheel studs replaced
Steering Stops
2024 Project list:
Transmission & Rear Differential fluids – Amsoil fluids
Aluminum Radiator
Energy suspension Body Mount bushings
Rear window replace – 4 panel (had the middle 2 panels busted a couple years ago)
Tint front windows 15%
Kilmat heat and sound insulation
Leaf spring and suspension upgrade (slowly but surely) - debating on custom progressive leaf springs and Bilsteins OR OME medium kit
Black hood swap or paint lol! (if anyone has leads on a black hood, let me know!)
EGR delete
Reupholster 60/40 seats
TPS replace
Timing belt job
LCE vacuum lines
VCG job
Old Dec 22, 2023 | 05:20 AM
FJ40_Nut's Avatar
You have a similar list as me and my '93. In your opinion was the LC Engineering H4 headlight conversion worth the expense? Thanks!
Old Dec 22, 2023 | 03:52 PM
I think so! Although, the previous headlights were pretty bad, so these were night and day difference in my opinion.
COMTB
38
Oct 17, 2022 06:03 AM
94yoder
Mar 6, 2016 09:24 AM
RamblinOn
23
Dec 29, 2014 10:39 AM
icebear
15
Oct 16, 2010 08:35 PM
