Trying to add lights to ashtray and lighter
Old Oct 12, 2023 | 08:26 PM
ChristGin's Avatar
This has me stumped...I have searched for way to long so I am asking for help finally...lol
I am trying to take the ashtray assembly out of an '89 and install it into my '93 but the harness is different. Assuming the '89 is SR5 or something...But I am hoping to figure out a way to make this work with as little of wiring (I suck at this) as possible.
ALSO...I cannot find any thread where people added a couple LED lights under the dash and hooked them up to the door / dome light. I may want to add those if I can do it all at once. Thank you.
Ashtray harness on 1993 has no lighting wires and is different from the 1989 truck. Also pictured is a single wire plug that used to go to stock stereo. It seems to be a ground that changes voltage while using the dimmer switch, but i am guessing here.
Ashtray light harness on 1989 truck is 4 pin.
Last edited by ChristGin; Oct 12, 2023 at 08:31 PM. Reason: Adding text, couldn't do it on phone.
Old Oct 12, 2023 | 08:34 PM
ChristGin's Avatar
1993 ashtray and lighter in lower console.
1989 ashtray and lighter with lights.
Old Oct 12, 2023 | 09:07 PM
ChristGin's Avatar
Still looking around here for threads regarding this. I will link to them here as I find them.
Hint perhaps...
Originally Posted by scope103
In 1993 (which may or may not help you; you don't give a year) the 4 pin connector to the cigarette lighter (C3) has G to Lighting, W-G to the Rheostat, then to Ground, GR-R to the integration relay then to Cigarette fuse, and W-B to ground.
taken from: https://www.yotatech.com/forums/f116/cig-lighter-ashtray-illumination-307923
Old Oct 12, 2023 | 09:09 PM
ChristGin's Avatar
Another hint..
Originally Posted by Discombobulated
When I added the cig light and ashtray light in my 91 that was not hacked by PO I did not have an existing plug to fit, I ended up tapping into the lighting for my climate control..
taken from: https://www.yotatech.com/forums/f116...nation-307923/
Old Oct 14, 2023 | 08:25 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I spent some time getting my first gen 4Runner lighter and ashtray to illuminate. And it doesn't have any sort of dimming feature, Just on/off.
The second gens are a dime a dozen in our local pick-a-part yards. I'd think it's be easier to go get a used one with the wiring and just plug in.
Old Oct 16, 2023 | 11:05 AM
keycw's Avatar
5 Year Member
there are multiple wiring configurations for the different models.. my 87 did not have the little light ring around the cig lighter or the lamp in the glove box. i gathered some of the parts but forgot about it eventually.
Terryyota
Feb 8, 2021 11:21 AM
Trail_Banger
14
Dec 24, 2008 01:59 AM
pius222
37
Oct 22, 2008 12:58 PM
vmax84
Sep 1, 2006 01:13 PM
white sr5 runner
Jun 17, 2003 01:47 PM
