Old gasket removing how?
Old gaskets are sticking as hell to surface and from cast iron as engine block easy to remove but what is the best way to get them off from alloy parts. You cant scratch with something sharp and make marks in the alloy so what is the best way to do it.
Well, the older gasket remover (methylene chloride) worked. Last automotive gasket remover (name brand) I bought worked a little bit. So if you've still got some old paint remover (pre-Obama), give that a try. Otherwise patience, some kind of softener stuff/solvent, and a single edge razor blade scraper. Careful! Don't scratch or gouge. I would not use Scotchbrite (research/readup on it) or any other abrasive (unless last ditch and with very great care. My $0.02.
From: exo-reality -wave if you see me; Front Range, CO
This. The real mechanics at "Big Evil Red Oil Services Company" used them. Some also used those eraser disk thingys like you'd use to remove decals.
If you have a lot to do I guess. I opt for old fashioned sharp razor, oil/solvent, and time consuming patience.
The issue with the eraser disc is that the old gasket material gets thrown around to who knows where and could end up in the cooling system ports or even the oil system where they find their way into the oil pump screen.
vmax84
Jul 31, 2006 03:14 PM
Bumpin' Yota
Jan 24, 2005 08:12 AM
