Ruff Idle when hot
Ruff Idle when hot
I have a 94 truck with a 2.4L and when it gets hot it idles ruff. When it's cold it idles fine but if I drive it for 15 min down the road when I pull up to a stop sign it starts idling low and ruff. Can anyone give me some suggestions on what to look for?
That's what he meant.
Of course, there's also the possibility that you knew I was trying to be sarcastic, in which case I've been zinged so well that I didn't even know it.
...and as for the truck, I might look into the temperature sensor or something to that effect. The sensor might be providing inaccurate readings to whatever controls the air/fuel mixture (i.e. running on a 'cold' mixture when it's too warm). At least, it seems plausible.
Originally Posted by whitehackle26
I have to mash the gas pedal sometimes to get it going.
Clean out the throttle body with some carb cleaner and a toothbrush and see if that helps.
Also do the typical tuneup stuff (plugs, cap, rotor, air filter, fuel filter)
Check the AFM and TPS for proper adjustment as well.
the1998sr5
15
Jul 14, 2020 08:35 PM
sojourner567
Jul 16, 2015 08:52 PM
