Ruff Idle when hot
Old Apr 23, 2004 | 05:39 PM
whitehackle26's Avatar
Ruff Idle when hot
I have a 94 truck with a 2.4L and when it gets hot it idles ruff. When it's cold it idles fine but if I drive it for 15 min down the road when I pull up to a stop sign it starts idling low and ruff. Can anyone give me some suggestions on what to look for?
Old Apr 23, 2004 | 06:01 PM
Yoter's Avatar
Guest
Get the timing & idle adjusted, change the fuel filter and dont run poor fuel in it. Im in the same boat but I ran regular fuel last fill up for wheeling.
Old Apr 23, 2004 | 06:21 PM
AgRunner06's Avatar
Adjust your idle and see if that fixes it.
Old Apr 23, 2004 | 06:40 PM
ilion's Avatar
I'm confused.
So it sounds like a dog's barking when the engine's hot?
Unless, of course, you meant rough.
Old Apr 23, 2004 | 06:48 PM
AgRunner06's Avatar
That's what he meant.
Old Apr 23, 2004 | 07:00 PM
Fahrenheit 451's Avatar
Have you been watching the temp gauge for any unusual spikes (i.e. gets hot really fast sometimes)?
Old Apr 23, 2004 | 08:24 PM
ilion's Avatar
I know, I know... I was trying to be sarcastic.
Of course, there's also the possibility that you knew I was trying to be sarcastic, in which case I've been zinged so well that I didn't even know it.
...and as for the truck, I might look into the temperature sensor or something to that effect. The sensor might be providing inaccurate readings to whatever controls the air/fuel mixture (i.e. running on a 'cold' mixture when it's too warm). At least, it seems plausible.
Old Apr 24, 2004 | 04:40 PM
The temp has been no problem. It starts a little hard as well when it's nice and warm outside. I have to mash the gas pedal sometimes to get it going.
Old Apr 24, 2004 | 05:44 PM
Yoter's Avatar
Guest
I am guessing a full tune up may assist in getting his rig running correctly. may need a fuel filter if you have to mash the pedal to get it going. Sounds as if it is starving for fuel IMO.
Old Apr 24, 2004 | 06:12 PM
MTL_4runner's Avatar
Clean out the throttle body with some carb cleaner and a toothbrush and see if that helps.
Also do the typical tuneup stuff (plugs, cap, rotor, air filter, fuel filter)
Check the AFM and TPS for proper adjustment as well.
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
mtc1105
Aug 4, 2015 08:06 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
sojourner567
Jul 16, 2015 08:52 PM
