Cold start injector sprays, but still no start
Old Nov 9, 2020 | 04:50 PM
prowe's Avatar
My 1992 Toyota pickup stopped starting in the mornings when it got cold. When it warmed up to around 70 degrees outside, it would start fine. I removed and cleaned the injector, then hooked it back up to the fuel line and checked the spray when I cranked it. The spray checked out good. I put it all back together and the engine started and ran great. I turned it off, then tried to start it 20 minutes later and it wouldn't start. It hasn't started since. I don't think it could be the cold start sensor switch because it sprayed fine. I am stumped as to why it doesn't start now. Also I will check the sensor with my ohm meter but I don't remember what the range is supposed to be.
Old Nov 9, 2020 | 06:18 PM
Co_94_PU's Avatar
The cold start injector doesn't have a sensor it has a cold start injector timer. You are barking up the wrong tree! My CSI is unplugged and the engine starts just fine in under three revolution.
Check the spark, check the fuel pressure.. Heat soaked vs cold.
Old Nov 9, 2020 | 09:05 PM
prowe's Avatar
Ok, so I sprayed starter fluid into my air intake and the engine started for a moment. So this tells me that I'm not getting fuel to engine. Next I turned the key to the on position and jumped the +B to the Fp terminal in the diagnostic box by the battery and heard the fuel pump come on. Then took the jumper off and turned the key when trying to start and did not hear the fuel pump. I have heard it could be the open circuit relay. Does anybody know where this is in the '92 toyota pickup?
Old Nov 10, 2020 | 10:54 AM
Co_94_PU's Avatar
Start and run the engine with the jumper in?
COR is above ECU behind glovebox.
ddv1126
Mar 24, 2021 07:51 AM
02 polish ss
Mar 20, 2012 05:53 PM
toastyjosh
Mar 4, 2012 09:44 PM
ls2camaross
Jan 13, 2010 06:13 AM
bigt
Nov 28, 2007 05:16 AM
