88 4runner electric window switch problems
Old Oct 7, 2019 | 05:48 PM
MapleLeaf's Avatar
Hi, I am having some issues with my driver and passenger power window switches. I took them both apart and the master switch needs to be replaced I think. Also I think I lost a contact for the passenger side window switch. Its pretty frustrating trying to take these apart and clean them, as the contacts like to go bouncing off. Does anyone know where I can get a replacement switch? Even used maybe?
Thanks!
Old Oct 11, 2019 | 05:23 AM
old87yota's Avatar
There are two styles of window switches depending on your door panel type.
If you have a flat door panel where the switch faces across the cab, there is a new passenger switch available from Switch Doctor: https://www.switchdoctor.net/toyota-...tch-1984-1988/
Unfortunately, they do not make a driver's side switch panel, or the fancier switch style.
For a used switch, you can look in your local auto salvage yard, eBay, Craigslist, etc.
You can also try Yota Jim's out of Denver, Colorado. They are a Toyota Truck and 4Runner only salvage yard: http://yodajims.com/
Once you reach 15 posts, you can post a "Want to Buy" (WTB) ad in the classifieds section on YotaTech if you are not having any luck.
Old Oct 11, 2019 | 06:17 AM
SomedayJ's Avatar
I cleaned the window switches of my '88 4R. They work perfectly after that. In case your truck has the same switches:
https://www.yotatech.com/forums/f116...roblem-299803/
Old Oct 12, 2019 | 06:20 PM
MapleLeaf's Avatar
I checked out Yoda Jim's, they seem to be pretty specialized in this sort of thing, Just what I need!
If I'm driven to rewiring the whole switch 'SomedayJ' that link will help quite a bit for sure.
Thanks for the links.
ign_cas
Sep 8, 2014 10:49 AM
hiloracerboy84
7
Apr 22, 2008 04:44 AM
ElwayLite
11
Dec 17, 2005 09:07 AM
Denk
Sep 9, 2003 04:09 PM
