93 rear window 'dead'
Old Apr 30, 2019 | 01:36 AM
tbst1337's Avatar
hi guys
i've got a problem with my rear window: it went down, but now it does not want to come up anymore, neither through the window switch near the driver seat nor through the key in the tailgate.
what i can hear is the sound of the relay near the left side taillights.
i have checked the blue connector that goes to the motor (on the pic) which gives me 0 or 12V depending on how i turn the key. i had this issue in the past, but about 10min later it worked again fine.
anybody got an idea how i can fix it and what is broken?
Thanks
Old Apr 30, 2019 | 02:05 AM
tbst1337's Avatar
another note: the rear window wiper also does not work now (window is in open position and cant close). i thought maybe letting the wiper run through would help, but it also doesnt move
Old Apr 30, 2019 | 12:26 PM
881stgen's Avatar
Have you tested the motor independently of all the switches? when I was testing mine I connected two wires from the battery to the motor. When I connected the second wire to the motor it started moving, so I knew the motor was good. It sounds like you are getting 12v to the motor so it makes me wonder if it's the motor? If the motor works then you can bypass all the safeties and ground the switch to a separate ground and see if it works then?
I am not the best troubleshooter but that's my first thought. I spent a lot of time with my rear window lol
Old Apr 30, 2019 | 05:25 PM
dropzone's Avatar
Fossilized
https://www.4crawler.com/4x4/CheapTr...arWindow.shtml
https://www.ether3al.com/runner90-95fsm/
did you trick your window into thinking the tailgate is up by tripping the tailgate locks (where it hooks to the truck on each side) with a screw driver?
\Gotta do that to trouble shoot stuff with the tailgate down
Old Apr 30, 2019 | 11:46 PM
tbst1337's Avatar
Not yet. I have to wait for my friend as he has all the equipment which I sadly dont have.
Thanks, i have tried that also tried the other stuff this guy suggested.
Old May 8, 2019 | 10:39 PM
tbst1337's Avatar
alright, we did test it. and it seems to be the motor. just ordered a new one off of rockauto (https://www.rockauto.com/?carcode=1272451&parttype=1516)
once it arrives, i will do the whole maintenance procedure according to this video as well:
Thomas Reynolds
Jul 13, 2017 07:09 PM
Uncle Meat
Aug 18, 2008 06:10 PM
jns
Jul 13, 2005 11:27 PM
tgreathead
May 6, 2005 05:27 PM
