Sponsored by: CARiD
1987 Toyota 4Runner 22re green electrical plug under intake
Old Apr 21, 2019 | 06:50 PM
Az4runner87's Avatar
1987 Toyota 4Runner 22re non-turbo. I have an green electrical plug under the intake manifold I do not know where it plugs into. (See first picture) it is part of the wire bundle come from ECU. other electrical green plugs are properly plugged in. (See pictures). Vehicle runs, but has fluctuating idle, will not pass emissions idle carbons, and losses power as motor increases to warm up (I believe this a different issue) does anyone know where this plug goes to or is not used? Than
I don’t know what this plugs into
Other plugs are correct
Correct plug
Correct plug
ks
Old Apr 21, 2019 | 07:12 PM
millball's Avatar
Idle air control plug??
Old Apr 25, 2019 | 02:27 PM
I’m pretty sure the idle air control works off vacuum
Old Apr 25, 2019 | 02:53 PM
millball's Avatar
Whatever you say.
My '87 22RE idle air control has 2 air hoses, two coolant hoses and an electrical plug. Vacuum?? Not really.
Old Apr 26, 2019 | 12:41 PM
Co_94_PU's Avatar
Air valve diagram..
Typically safe to assume this era wiring goes to what it reaches, while noting the tell tales of the kinks and bends.
Old Apr 29, 2019 | 08:53 AM
Originally Posted by Co_94_PU
Air valve diagram..
thanks. I’ll check that
Old Mar 14, 2024 | 10:13 AM
Theextra thumb's Avatar
Hi, I'm having all the exact issues with my toyota 4runner 22re. Solution found?
I have the same model with the same problem and Ive been looking at the same wiring bundle unable to find where two wires and a hose go... Did you ever find some peace in this matter, lol. I can't figure it out and it starting to feel like Ive been at it... way to long for this kind of thing, lol. SOS
emsflex
Mar 22, 2015 07:04 AM
dirtdobberoffroad
Nov 27, 2013 02:55 PM
crawler85
Nov 18, 2012 03:36 PM
ravenr106
Oct 4, 2012 03:22 PM
mean green
Aug 25, 2007 06:37 PM
