Anyone have the LC Engineering Pro Flow Exhaust for 3VZ?
Hi Everyone,
Does anyone run with the 3VZE the LC Engineering Exhaust Kit? It is the magnaflow muffler (the salesman confirmed for me). I have the LC Engineering headers, and I would buy a 17" Cat to put on the truck with the exhaust. LC Engineering did not have a video of it running... I want to make sure there isn't much drone at 70 mph.
I like this setup because it's bolt-on, I can do it without taking it to a shop.
Thanks!
Thanks!
https://www.youtube.com/watch?v=luJmeqUNhdY
Looks like you already got your new exhaust. Either way, check out the install I did on the LC kit,
You mentioned in your reply there that the cat you ordered from LCE but it’s a magnaflow 91005. That magnaflow PN however matches a straight through version without flanges. Not relevant to the swap I’m doing as it’s pre-OBD II but still odd, unless they’re buying the 91005 and welding the flanges on themselves.
Another thing is I noticed that’s a Street Max muffler in your video. LCE used to use magnaflow, so interesting to see they swapped to a different brand.
all in all, sounds good in your video. Thanks for uploading that, there isn’t a lot of content around 5th gen V6 trucks and exhaust.
Heh, I commented on your YouTube video, too.
Glad you watch the video! I checked LC Enginnerring's site and the cat I used in the video has a different part number than the manufactuerer. #1043012.
Also I was not aware that the muffler they used was supposd to be a Magnaflow unit. It says on their website that its a "Street Max Muffler".
I suppose that Its a subsidiary of Magnaflow. Either way its a good system.
