Battery and Brake Light stays on
Old Oct 3, 2018 | 01:50 AM
1994Toyota4X2's Avatar
Last night I flushed my heater core and I think I shorted something out. After the flush, I drove around for a bit and the Battery and Brake lights came on (see pic)
1994 Pickup
22RE
Any suggestion how to fix the problem?
lights
Old Oct 3, 2018 | 03:19 AM
Discombobulated's Avatar
Mine did this when my alternator was failing, hows your voltage output?
Old Oct 3, 2018 | 08:53 AM
scope103's Avatar
As Discombobulated suggests, put your multimeter right on the battery posts. You should get about 12.6v with key-off, and about 14.1v with engine-running.
Don't try to diagnose this without a multimeter. They're cheaper than dirt, and they are the only tool that works.
Old Oct 3, 2018 | 11:14 AM
snippits's Avatar
Did you remove the water pump coolant hose to pipe without putting a shower cap on the alternator? If you did, you soaked the alternator. If not, then carry on.
Old Oct 3, 2018 | 02:37 PM
RAD4Runner's Avatar
Originally Posted by 1994Toyota4X2
Any suggestion how to fix the problem?...
Like Scope says^^^ and search "how charging system works"
Old Oct 4, 2018 | 02:15 AM
I wish I did. Where were you on Sunday?
I am going to take off the alt and change the regulator and brushes. It's the OEM ALT so very likely the problem. I'll also take a reading to see if I am on the right track.
Thank you Toyota gurus.
Old Oct 4, 2018 | 05:32 AM
scope103's Avatar
Odd. If you're getting 14.1v at the battery posts, are you STILL going to remove the alternator? Because it's OEM?
Old Oct 4, 2018 | 01:39 PM
Update - I am getting 12.6 at the battery and it doesn't change when I turn the engine on.
Old Oct 4, 2018 | 02:50 PM
scope103's Avatar
Okay, now what? You could just replace the alternator on the blind. There's a chance that will fix your problem, and if it doesn't, you're only out $125 or so.
Or, you could check the voltage at the alternator output (fat wire). And check the excitation voltage (red wire; should be battery voltage with key-on). If you have no output but do have excitation voltage, most auto parts stores (O'Reilly's, Autozone) will test your alternator "for free." (They want you to buy the replacement there.)
Old Oct 17, 2018 | 01:46 PM
I am up and running
Took the alternator to a shop and had it rebuilt. Lights are off and my is truck is happy
Old Oct 17, 2018 | 02:13 PM
old87yota's Avatar
Yay!
A happy truck makes for a happy owner!
Old Oct 17, 2018 | 05:06 PM
87-4runner's Avatar
Good call on the repair... thank you for posting your outcome!
Aleeex_u
Jun 5, 2016 06:52 PM
gary96360
Jan 5, 2011 06:53 PM
rustyboltz
Mar 12, 2010 03:17 AM
mdhunter
Mar 13, 2006 04:21 AM
bamboo89
13
Dec 25, 2005 10:00 AM
