Wiring diagram needed. 1990-1994 pickup or 4Runner.
Old Sep 11, 2018 | 08:55 PM
cntrails's Avatar
Does any one have the wiring diagram for this?1990-1994 pickup or 4Runner.
Thank
Old Sep 12, 2018 | 12:31 AM
wyoming9's Avatar
Red face
Just which one do you need 4Runners and Pick Ups can be different enough to cause major frustration
The years can be also just different enough.
Just what are you trying to do??
Old Sep 12, 2018 | 02:50 AM
cntrails's Avatar
I am trying to repurpose the switch. This one has one yellow, one red, one white/green and one white wire. I am trying to figure out how it is wired to send current to the instrument cluster.
Old Sep 12, 2018 | 05:24 AM
scope103's Avatar
That's what a multimeter is for.
I'm almost certain that the switch contains an incandescent bulb. I would expect to find one pair of wires with low (but not zero) resistance for the bulb, and another pair that goes from open to short as you activate the switch.
But I could be wrong about the bulb. The switch could be SPDT, or DPST. Your multimeter will tell all.
I don't have the EWD that shows the connector to that switch, though.
Old Sep 12, 2018 | 12:01 PM
RAD4Runner's Avatar
You can do as Scope103 says ^^^
Or have fun with this (LOL!)
Of buy a $5 switch.
Old Sep 12, 2018 | 03:50 PM
cntrails's Avatar
I have tried it every combination but the right with a multimeter. I am just stuck. I can get it to turn the pwr (orange) light on in the instrument cluster thru the switch but not the green light. I want both to work.
Old Sep 12, 2018 | 03:58 PM
RAD4Runner's Avatar
Originally Posted by cntrails
... but the right... I can get it to turn the pwr (orange) light on in the instrument cluster thru the switch but not the green light. I want both to work.
Which "right"
Which "orange" light?
Which "green" light?
Pls see signature.
Old Sep 12, 2018 | 04:47 PM
cntrails's Avatar
cntrails , 09-12-2018 11:50 PM
I have tried it every combination but the right one with a multimeter. I am just stuck. I can get it to turn the pwr (orange) light on in the instrument cluster thru the switch but not the green light in the instrument cluster. I want both to work.
Old Sep 13, 2018 | 12:03 AM
wyoming9's Avatar
Red face
You have made sure the green bulb works??
Old Sep 13, 2018 | 03:08 AM
cntrails's Avatar
It does. I think I have it figured out. I took the switch apart and I am going to have to modify it to make it work the way I want it to.
Dawgz
Aug 12, 2023 04:04 PM
toystoplay
May 4, 2011 12:46 PM
Dropmytaco
May 26, 2010 07:27 PM
Bob Ross
Aug 13, 2009 03:40 PM
bud_rabon
Jun 16, 2006 05:52 AM
