Installing a tachometer
Old Jun 12, 2018 | 03:44 PM
Redsqueal's Avatar
I’ve got an 88 Toyota Pickup with the 3vze, and I’m wiring in a tach. I’ve got everything wired in and it works, but I can’t fine the ignition wire so that the tach will come on when I turn the key. Does anyone know where an easy to get to wire is in the cab that I can quickly wire it in???
Old Jun 12, 2018 | 11:20 PM
wyoming9's Avatar
Red face
So you need switched power ??
This wire going to the tack has a inline fuse ??
I would use the 15amp Cigarette lighter fuse that way if you have problems nothing critical stops
Old Jun 12, 2018 | 11:31 PM
Thommo Thompson's Avatar
The car stereo is the first place i go for switched power. however it might be a bad idea on an old car because it could cause interference which could make its way into the speakers, especially coming from literally the worst part of the car for interference, the ignition system.. give it a try tho.
Old Jun 13, 2018 | 05:56 AM
RAD4Runner's Avatar
Post a picture of fuse blocks in your engine and cabin.
Find Engine fuse. On the 22RE that powers the tach is installed. Connect to wire that only has power when fuse is inserted. (Red in the case of 22REliable).
Attached Thumbnails Installing a tachometer-screen-shot-2018-06-13-7.00.13-am.png   Installing a tachometer-screen-shot-2018-06-13-6.59.36-am.png
LITLRED
Feb 6, 2013 11:16 PM
94SDPickup
Oct 16, 2005 05:19 PM
khamm03
Nov 30, 2003 10:53 PM
Whitey
Nov 8, 2002 03:30 PM
