can you use a tie rod end after you remove it?
Old May 27, 2018 | 09:45 PM
Runnerbuddy's Avatar
i have started taking my tie rod off and have got to the point to take off the outer tie rod from adjusting sleve, this is a 1992 4runner 2nd gen, if i remove the the inner end, would i be able to use it again after? i cant get the outer one out, she old and a bit rusted, have loads of wd-40 but do you have any ideas?
Old May 28, 2018 | 04:05 AM
wyoming9's Avatar
Red face
Yes you can as long as you don`t damage the threads or the boot
WD-40 is not a very good penetrative I use Kroil myself
Once the sleeve locking bolts are loose it should come right out
Old May 28, 2018 | 04:38 AM
scope103's Avatar
PB Blaster is also considered to be a good penetrant. Keep in mind that you can buy all three parts (inner, outer, adjusting sleeve) for as little as $13 from RockAuto. No one on this forum likes to replace parts that CAN be re-used, but don't break a knuckle over that kind of money.
Old May 28, 2018 | 08:39 AM
thefishguy77's Avatar
If you have to reuse it be careful you dint damage it. But if you have a few bucks, a lot of the time its worth the time savings. And if you get your old one out undamaged then you can jeep it as a spare.
As stated above don't use WD40 as a penetrating lube. It stands for Water Displacement 40 attempt. Kroil or PB Blaster work well. You can also try Deep Creep by Seafoam.
2JZRunner
Sep 13, 2024 07:21 AM
CreeperSleeper
2010+ 4Runner (Build-Up Section)
26
May 16, 2024 01:18 PM
schil01-camper
May 6, 2018 08:07 AM
