Test fuel pressure 91 3.0 4runner
There is no "Schraeder" valve. So you can add one yourself: https://www.ebay.com/itm/Banjo-Bolt-...-/251254996574
The easiest place to add it is below the fuel pressure regulator:
https://www.yotatech.com/forums/f116.../#post52330847
I left mine permanently installed. If you want to take it on and off, you MUST replace the two crush washers each time. Cheaper than dirt, but the only place I've ever found them is the dealer.
ThomasJ
Aug 27, 2005 05:38 PM
