toyota 4runner 98 elocker
toyota 4runner 1998 i have the whole elocking wire harness the only wires i see to put power to is yellow/blue stripe and a hevier gauge blue with red stripe which one would i put power to. I'm trying to figure out how it gets power to the ecu from factory. I'll post pics. I went to junk yard 2 days ago they sold me 2axles and they told me to go grab harness for it got everything for 300 2axles and harness.
Interesting the wires coming from the fuses are Black with a Yellow stripe .
Your sure this is factory ??
From a 98 4Runner .
You have the complete harness with the Diff Lock ECU?
From a 98 4Runner .
What are you trying to do? Wire up an e-locker with or without ECU, or test the motor?
There should be two heavy gauge wires for the motor, on mine it's light green and light green/red stripe
Yellow/blue is the locker sensor, do not apply power to it.
Post 1884 has a diagram that shows what wire does what in the elocker plug
https://www.yotatech.com/forums/f200...1/index95.html
toyota elocker
I don't want to cut to much if I don't have to I'll post pics in the morning trying to figure out how it got power from factory not by during near the RR did lock switch in dash
Are you trying to install an e-locker into your 4Runner and trying to wire it up, OR are you trying to troubleshoot a problem with a factory installed e-locker?
I also have complete harness for a 5speed manual with elocker plugs for ecu and RR diff switch don't have the want to tare whole dash out to replace whole dash harness. I don't have a power source to power harness might go back and get the manual computer and complete engine harness to power harness to figure out how it truely gets power by poking and proding
You'd prolly benefit from reading BigFishAllDay's huge amount of work and information...
within his build thread:
Start with post 457, he retrofitted an elocker including the locker ecu into an '01 which never came with an e-locker. In the process he put out a ton of great into and wiring info:
http://www.toyota-4runner.org/3rd-ge...ml#post1038490
and in a nutshell thread Posted by BrianSD 42:
http://www.toyota-4runner.org/3rd-ge...ay-quoted.html
I know myself I would not want to try this without both EWD`s for both vehicles .
Like any other harness merging projects I seem to fix after the first few attempts and many fuses
building a 6x6 95 4runner
2 drive axles will work full time 2 rear axles both with Toyota elockers haven't taken photos yet . I'm n process of cutting the rear off at the back of the wheel well and adding another section of a 4runner
FourBy4Toy
Mar 28, 2009 05:22 PM
pillguy
Jan 27, 2009 04:15 PM
montypower
Feb 18, 2007 03:38 PM
