95 4Runner 3.0 CRANK NO START...
Hello all who are willing to put up with my problems and help me out. Ok so I had another posting that was about the fuel pump mostly that was a while back and I have since got the fuel pump working. Now that did not solve my issues whatsoever... I have a strong spark to the plugs, its getting gas through at least the cold start injector, and my timing belt is intact and good. I have sprayed starting fluid into the throttle body to see if that helped to no avail. I will need to swap out my battery most likely after this but i was definately wanting to fix the issue at hand first. Any ideas world of Yota??
Not even firing?
Really low compression would do that. It's a $20 tool to check it.
Timing way off would do it; another $25 tool. But you could be 180° off and the mark would end up in the "right" place. You might need to remove the valve cover to compare the valve position to the distributor rotor.
Cam off should show up as low compression.
I finally got off work in time to do some digging and checked the compression. All cylinders are at 120... Im going to look at the timing some tomorrow while im off. Anything else i should probably look at while im out there?
Ok starting the day off. Im going to keep an eye out on the forum so i can see if anyone has an idea while im doing this. Going to go ahead and recheck all the spark to plugs since i already have them all out as well.
t3banshee
May 4, 2014 09:01 PM
5.9ford
Dec 6, 2012 05:20 PM
