Accidently poured 5 gal of water in the fuel tank
Old Oct 20, 2017 | 11:40 PM
barracuda217's Avatar
1992 Toyota pickup 4 x 4 22RE 5 gal of water in fuel tank and ran it till it died. Siphoned the tank dry put clean fuel in and drove it home sputtering jerking dying at full throttle but idles fine. got home drained the fuel tank blew out filter put in good fuel and it still runs just the same. ?? is it water still in fuel lines ?? Fuel pressure low or dirty mass air flow
sensor dirty from backfire
Old Oct 21, 2017 | 07:48 AM
gsp4life's Avatar
Since you had your injectors spraying water into the combustion chamber until it quit running, there's a slight possibility you have a bent valve. Run a compression test and then test again with a shot of oil in each cylinder to help separate top end vs bottom end compression losses.
Btw, how did you manage to get 5 gallons of water into the gas tank?
Old Oct 21, 2017 | 08:03 AM
gsp4life's Avatar
I thought about it for a minute and remembered this stuff called "Heet" that I used to burn in penny alcohol stoves for camping. It's actual purpose it to remove water in fuel systems. Give it a shot, it's cheap and been sold for a long time for the exact problem you're having. There could still be water in there, especially if you didn't let the tank dry after siphoning, same with the fuel lines.
Old Oct 21, 2017 | 09:26 AM
scope103's Avatar
Water is heavier than gasoline, so it sits in the bottom of low spots in the line and doesn't get "flushed" out through the engine. Heet is Methyl Alcohol (yeah, you could use the real Methyl Alcohol from the paint store, but Heet isn't that expensive). Methyl Alcohol is miscible in water, which means it dissolves into the water and helps it get flushed through the system.
So, yeah, I would try that. And it sure wouldn't hurt to replace the fuel filter (you can't "blow it out"). The water may have partially dissolved some water-soluble gunk sitting innocently in the fuel system for years, and the fuel filter would have done its job and tried to grab it.
Last, whenever you run muck through the fuel system, there is always the small possibility it made it all the way to the injectors. The inlet to the injector has a small screen (replaceable) that can get clogged.
Old Oct 23, 2017 | 12:04 AM
wyoming9's Avatar
Red face
We never did hear just how this happened ??
Working on a water fueled engine had a little issue with breaking it down to hydrogen and oxygen ??
Old Oct 23, 2017 | 07:12 AM
scope103's Avatar
if a little works, more should be better.
https://en.wikipedia.org/wiki/Water_injection_(engine)
Old Oct 23, 2017 | 07:22 AM
dropzone's Avatar
Fossilized
i tried to see how well VW Baja would float in high school. It sunk,
recovered it, drained all the fluids, refilled tank with one gallon on IPA (isopropryl alchohol) and gas, it was running an hour later
so did you fill it from a hose bib at your house?
Old Oct 24, 2017 | 07:08 AM
ksti's Avatar
Old Oct 24, 2017 | 03:13 PM
lifeinajug's Avatar
Guessing someone put water in a fuel canister...
Old Oct 24, 2017 | 06:45 PM
scope103's Avatar
Could be (a lot) worse; gasoline in a water container.
Old Oct 29, 2017 | 06:50 AM
gsp4life's Avatar
Ah, so the OP had a vengeful ex. My guess was he woke up a little foggy one morning, grabbed the garden hose to top off before heading to work.
Old Oct 29, 2017 | 10:15 AM
Prafeston's Avatar
Impressive. PO too embarrassed to come back?
tjcole
Vendor Advertising
28
Feb 14, 2013 07:56 PM
JHRRLD
Jan 10, 2007 02:48 PM
