How do you remove this lock?
Old Sep 6, 2016 | 08:31 PM
Nervo19's Avatar
I know the U shape clips comes off but it does not budge. I'm afraid of breaking it. I've done an extensive search and can't figure it out. What tool do I use? This is a pic from the internet but mines a 1st gen 4Runner:
Old Sep 6, 2016 | 09:46 PM
boostaddctn's Avatar
flat head screwdriver and pry upwards from inside the U... might help to turn it a little so it has room to pop out... good luck
Old Sep 6, 2016 | 10:15 PM
old87yota's Avatar
Is the clip rusted into place?
In the past, I have just taken a pair of pliers and just pulled these types of clips free. However, I have only done this with license plate lights in an aftermarket bumper so the spring force wasn't very strong.
All I can think of is letting it soak in penetrating oil and try to get the clip to rotate a little before pulling it off.
Old Sep 6, 2016 | 10:53 PM
Terrys87's Avatar
On the picture above, I put a flat blade against the top of the clip and push it in an upward motion. It is just held in place by pressure of the bent tabs. Sometimes a good thump with the heel of your hand on the screw driver is needed. Make sure it is not corroded to the door but it is most likely the pressure holding the clip.
Old Sep 8, 2016 | 03:56 PM
scope103's Avatar
Like everyone else says.
The good news is that the clip is VERY standard. If you break yours, any locksmith will have a box of replacements.
Old Sep 9, 2016 | 02:44 PM
wyoming9's Avatar
Spray penetrating lube of your choice will work wonders
Those clips are spring steel they might bend I have never had one break .
Even beating one off with a hammer and Chisel
Old Sep 10, 2016 | 05:36 PM
RAD4Runner's Avatar
Yes, yes and yes.
aowRS
18
Sep 7, 2025 09:52 AM
Iceman4193
Sep 10, 2016 10:14 AM
cleavel
Sep 6, 2016 03:37 PM
L4g63t
Sep 3, 2016 08:17 PM
dfarr67
Aug 30, 2016 10:20 AM
