The Guy at Toyota said I can use between 1986- 1992?
Fuel pump bracket needs to be replaced. I have a 91 toy 22re. My question is. What other years can I use, if I was to find a used fuel pump bracket? The rep at the dealer said from 1986- 1992. Does this sounds correct? Thanks.
Tanks differ between 2 and 4 wheel drives and also by each generation. Since you have a 91 you can use 89-95 but even then there can be some differences. Pay attention to the length of the bracket that holds the pump. The 85-88 metal hoses coming off of the tank are not as long as the 89-95. It probably could be made to work but you really need to get the correct assembly for your truck.
Terrys87 describes the issue well. Here's what I said in Diego_toyota's other thread:
https://www.yotatech.com/forums/f116.../#post52328786
