jhuggz 93 pickup
Old Mar 9, 2016 | 11:24 AM
jhuggz2502's Avatar
jhuggz 93 pickup
Not sure if this is the right place to ask questions but i need some experienced advice before i go blow a bunch of money and things not work out. going with a 3.5 inch fabtech lift. curious if 15x8 with 4 inch backspacing rims with 31 inch tires will be too big? thanks for comments in advance
lift -
http://www.4wheelparts.com/Suspensio...&t_pn=FABK7017
rims -
http://www.summitracing.com/parts/crr-3425812/overview/
Old Mar 9, 2016 | 12:51 PM
rustED's Avatar
You should be able to fit 31" tires without any lift. With a 4" lift you could run 35's, but would need to change the gears to 5.29's.
Old Mar 9, 2016 | 01:35 PM
jhuggz2502's Avatar
i dont want to mess with the gears just need some clearance and really dont want to worry about rubbing. idc if i cant u turn just on normal turns and semi tight turns
Old Mar 9, 2016 | 03:42 PM
rustED's Avatar
Sorry, I didn't read your original post very good, you stated a 3.5" lift, I don't know where I came up with the 4" lift from, lol.
Anyway, if your only wanting to run 31's you should be fine without a lift, alot of guys are running them without problems.
Old Mar 9, 2016 | 07:08 PM
jhuggz2502's Avatar
thanks for the info man. that would be sick if 31s would work with no lift. forsure save me lots of money. just need to change out my shocks cuz the stock ones are done
Old Mar 10, 2016 | 07:19 AM
RainSR5's Avatar
31's will fit a 4x4 with no lift, but certainly NOT fit a 2wd Pickup with no lift.
With that width of a wheel 31's would probably rub like crazy on the front.
Old Mar 10, 2016 | 06:21 PM
jhuggz2502's Avatar
ya mines a 2wd. Is that fabtech lift good enough? too expensive? etc. If not what would you guys recommend? Im new to all this so any tips/suggestions are very appreciated
Old May 11, 2016 | 07:02 PM
jhuggz2502's Avatar
UPDATE:
Finally got her lifted...
31" mastercraft tires
3" summit racing body lift
Pro comp stock replacement shocks
10 full turns on torsion bars
Grinded the front fenders bigger
Heres the before and after pics...
Still on the to do list:
Go to the desert to break her in
Install lightbar
Bend bumpers
Paint flat black or coyote tan
Buy shell or toolbox
Only bad thing is on unlevel tight turns or going into some driveways the front rubs a little bit (level turns no problems at all), not sure how many more torsion bar turns we can do before the tires bow. Might have to get the fabtech lift kit since its pretty much the only thing available for a 93 2wd. Shouldve went with 30" tires and I wouldve been fine but this is my first truck that I lifted. Thanks for your time!
Attached Thumbnails jhuggz 93 pickup-20160406_153444.jpg   jhuggz 93 pickup-20160429_122344.jpeg
bigmumbles69
Feb 29, 2016 08:05 AM
marcfj-45
Feb 27, 2016 01:23 PM
Davidtank95
Feb 18, 2016 02:39 PM
Dustin Egle
Feb 17, 2016 04:56 PM
Poppie51
Feb 10, 2016 08:42 PM
