Horn repair in 85 ExtraCab
Old Dec 20, 2015 | 05:25 PM
fasterspider's Avatar
After reading some threads here on Yota Tech I saw how easy it was to fix the horn proper by replacing the worn out brass contact pin. Before my new pin got here I rigged the horn by shimming the brass ring plate enough to contact the worn pin and the horn kind of worked.
Today I fixed it proper.
Removing the steering wheel this time was easy because I just replaced the heater core last week and had the wheel off then too but, that aside for me it was a breeze to change the pin.
I relieved tension in the small wire harness after removing the 4 set screws that hold the big switch down to the column and pulled the whole thing over the top of the steering shaft and held the pin up to remove the circlip.
The new pin from Toyota was only $5.00 and the new spring has quite a bit of tension compared to the old one so I had my buddy hold it in place while I put the new circlip in place.
After reinstalling the main signal, horn and wiper control switch and getting it all fastened in, the horn blew louder than I was prepared to hear and my neighbor was slightly irritated but, my horn works as designed now and it only cost $5.00 to do it right.
Old Jan 4, 2016 | 06:45 AM
When I ordered the brass contact pin somehow they sent me an extra a week later and I now have an spare.
Does anyone want their horn to work with a fairly simple and inexpensive fix?
Old Feb 4, 2016 | 09:42 PM
1985 4Runner's Avatar
I could use it, my horn is broke. I pulled it out from the grill & jumped it off the battery & it worked so I know its not the horn. Might be this contact pin.
Old Feb 5, 2016 | 06:01 AM
Call me and we can get you the pin.
818-259-8690
Old Feb 6, 2016 | 06:07 PM
twasabug's Avatar
I just attached a door bell button to the horn wires LOL. Works good. Put it on black part of dash
Old Feb 9, 2016 | 07:52 AM
stioc's Avatar
My horn doesn't work and I suspect it's the same ring issue. What's the part# and where did you order your's?
Old Feb 22, 2016 | 10:50 AM
818-259-8690
Been offline & just saw this, will call you right away. Thanks.
Old Mar 12, 2016 | 06:25 AM
stioc's Avatar
I too had the horn problem since when I bought my truck. I just got done replacing the pin. I searched for the part# all over for a while so if anyone else needs it it's:
Toyota part# 84312-20011 (it comes with the pin, spring and the little circlip).
Old Mar 12, 2016 | 07:13 AM
I had to mail you back your money dude, I lost the pin in my garage.
Big Little Bear
230
Nov 13, 2023 11:42 AM
Jonny246
Oct 16, 2015 02:50 AM
mj928
Oct 12, 2015 07:08 PM
Jamie Flores
Oct 10, 2015 01:12 AM
