PN 89661-35350
1990 pickup 4wd m/t 3.0
It has 10 pin ,18 pin and 24 pin connectors .
Truck will not run with TPS plugged in, I think I need to check the resistance of the wiring to the ECM.
The 1993 FSM is different, done many other searches as well.
Here is the pin out I use http://media.photobucket.com/user/ad...g.html?filters[term]=1989 toyota pickup ecu pinout&filters[primary]=images Toyota does like to change some wire colors from year to year when everything is the same. It can be frustrating.
Not sure what happened, it is someone else's Photobucket I have a link to https://www.yotatech.com/forums/f199...l#post51897320 When I click on it, the ECU pin out is showing for an 89 which is close to yours. Let me know if it shows up wrong if you don't mind.
When I go to the link in the post above this one, there is a link to the Nissan. Going to the link from my thread it takes me to the Pinout.
OK I can see Terrys pic but it's not the same. Mine is 10/18/24 pin connector for 3vze 1990.
Yeah the ecm may have been fried when I bought truck but it will run without TPS connected. Hate to install another ECM and cook it too.
