Tranny/Transfer case questions
Old Sep 3, 2015 | 05:35 AM
eggens's Avatar
Hi, hopefully a couple of easy questions for one of the experienced Toyota guys out there. We're putting a '92 pickup back together, 22re, 5-speed, 4wd:
1. Do the transmission and transfer case share fluids, or do we need to fill them with gear oil separately? I know you can just dump the trans fluid into the shifter opening prior to installing the shifter. If it's separate, do we fill the TC from the plate on top or is there a fill hole in the side somewhere?
2. In bolting the tranny and TC together, two of the bolts are bottoming out before pulling the two together. I'm thinking there must be a bracket that goes onto a couple of those bolts, but I'm blanking out (it's been over 6 months since I disassembled). Can someone help me out with that?
Thanks!
Old Sep 3, 2015 | 05:43 AM
Terrys87's Avatar
They fill seperately. You can over fill it or under fill by going thru the top. Fill from the side until it comes out the fill hole.
I cant see the front shaft dust cover making the bolts bottom out but it possible.
Old Sep 3, 2015 | 09:11 AM
eggens's Avatar
Thanks, Terry's 87. On the second question, I'm actually talking about the (6) bolts that bolt the transfer case onto the back of the transmission, so right above your forearm on that pic. For some reason, two of the bolts are longer, and I'm betting on some sort of bracket.
Old Sep 5, 2015 | 12:16 AM
wyoming9's Avatar
Red face
6 months I bet some of the bolts got mixed up
i am pretty sure they should all be the same length I don`t recall any brackets on any of those bolts.
Then I could be wrong
priest16
15
Aug 6, 2015 07:43 AM
yourrealdad
Jul 29, 2015 11:08 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
89hilux1
Jul 19, 2015 01:32 AM
crashburnoveride
Jul 10, 2015 06:39 AM
