93 4runner Annoying squeal
Old Nov 27, 2014 | 09:05 AM
Charecter1's Avatar
Hey guys, I'm having a problem with my rear left wheel squealing LIKE HELL between 0 and 20mph, I don't even need to be braking for it to squeal. I took the drum off and the pads look almost new and I didn't see anything wrong so I just adjusted the screw to bring the shoes in and the problem was gone until I pressed the brake pedal again so I don't know what's going on. Its a 1993 toyota 4runner 3.0 auto.
Old Nov 27, 2014 | 11:13 AM
rworegon's Avatar
Return spring not set-up correctly? Brake cylinder frozen?
Old Nov 27, 2014 | 05:17 PM
ksti's Avatar
^As stated above.
Also shoes my look good but might be glazed.
Start with the basic's sand shoes, check for hard spots ( burn spots) on drum surface.
Have you driven with e-brake on lately?
Pull the shoes off and re-grease backing plates.
Old Nov 27, 2014 | 05:36 PM
Charecter1's Avatar
Originally Posted by ksti
^As stated above.
I haven't driven with the ebrake on, I was g going to clean and lube everything and see if that helps, the right shoe was rough at the bottom and it felt like sand paper.
Old Dec 4, 2014 | 09:58 PM
Charecter1's Avatar
Okay so update on the truck, I replaced the hardware shoes and cylinder but now the brake light is on and fluid isn't going to that wheel so u have no brakes on that wheel. What do I do?
Old Dec 5, 2014 | 02:51 AM
rworegon's Avatar
Did you bleed the brake system after doing the work?
Old Dec 5, 2014 | 07:23 AM
Charecter1's Avatar
I tried but I can't get that wheel to bleed.
Old Dec 5, 2014 | 07:29 AM
rworegon's Avatar
Does brake fluid come out of that cylinder when the valve is opened?
Did you properly adjust the shoes before putting the brake drum on?
Old Dec 5, 2014 | 10:59 AM
Charecter1's Avatar
No, no fluid comes out, I adjusted the shoes until the drum Sat tug
Old Dec 5, 2014 | 11:47 AM
rworegon's Avatar
You'll need to determine if fluid is getting to the cylinder. Remove the brake line from the cylinder and see if fluid is at that point.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 16, 2015 06:16 PM
