86 runner fuel leak pics
I have a 86 runner 22re that just developed a pretty big leak while running. I lifted the metal cover and found the rubber line that runs into a metal line by the frame is leaking. the fitting is leaking and one of the small lines on the frame is leaking. heres pics is there anywhere I can buy the fitting or line.
Oh, man! Can't tell a thing from that picture.
Take a look at this; see if you can find the part you want.
http://www.toyotapartsoverstock.com/...rimLevel=18293
I know the fuel system quite well on the 22re and I too cant make out where you are showing with the picture. As I understand what you are saying, the metal line on the frame, I have gotten some out of the boneyard. I cant recall right off but one of them metal lines is discontiuned by Toyota, but may still be available from above or elsewhere. If it is the metal line on the frame, it should be the bottom one and can be swapped out from the front but it takes some patience.
6th Gear
19
Dec 10, 2019 07:31 AM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
94 First Responder
13
May 28, 2002 05:57 AM
