How to align front and rear bumper (86 4runner)
Old Sep 17, 2014 | 02:16 PM
Juke's Avatar
After searching, i havent been able to find a good answer. I already have an 86 4runner and possibly going to buy another one. The only thing about this one is the front and rear bumpers have been damaged, but is otherwise in good shape.
Im wondering if this is worth fixing or if it will be a headache trying to get them to line back up properly.
My question is what is the best way to go about aligning them? Can i simply replace them with a new/different bumper or will i have to bend/pull things back into place? If its simply buying new brackets and sourcing new bumpers i dont mind doing this, but im not sure about bending it.
This truck is going to be semi-restored (new paint, etc) and i want it to look factory fresh. My other runner will probably see some torture. Thanks!
Old Sep 17, 2014 | 02:37 PM
wyoming9's Avatar
Red face
Welcome to Yota Tech.
The best answer is maybe
No way to tell what your getting into till your underneath looking and measuring.
If the bumpers are dinged up no big deal.] If it is only the bumpers I would buy it just because if the price was right.
You can make front and rear bumpers
If the hood and fenders are buckled that is a big difference.
Take some pictures
Old Sep 17, 2014 | 04:35 PM
Juke's Avatar
Thanks for the welcome and the input! I tried making an account a while back but apparently im a spammer.
Here are the best pics i could get from them:
Front
Rear
The hood, fenders, and grill all seem to line up. The front looks to be pushed in and the obvious gap on passenger side. I havent been able to see the car in person yet. Anything i should look for that will tell me whether ill have to bend it back or not?
Thanks for taking the time to help out!
Old Sep 17, 2014 | 04:47 PM
Juke's Avatar
First attempt failed. Only letting me attach 1 image at a time. Must be doing this wrong..
Attached Thumbnails How to align front and rear bumper (86 4runner)-image.jpg
Old Sep 17, 2014 | 04:48 PM
Juke's Avatar
Front passenger side and fender
Juke's Avatar
Front driver side and fender
Old Sep 17, 2014 | 04:49 PM
Juke's Avatar
Front passenger side fender again
Old Sep 17, 2014 | 04:50 PM
Juke's Avatar
Rear. Need four more words
Old Sep 17, 2014 | 11:13 PM
wyoming9's Avatar
Red face
Is your final goal to have it look factory original??
Being it is a 86 finding new bumpers from Toyota will be very difficult you most likely will end up with after market.
Other then the dinged bumpers the paint looks better then any of the ones I have.
If the price is right and the rest is in good shape go for it.
Old Sep 18, 2014 | 12:13 AM
Juke's Avatar
Luckily i have another one in my driveway with all the original parts i would need to swap over. So one could be factory original while the other could be aftermarket or just sit around until i source the oem parts to but back on.
In your opinion, just from the pictures given, would you guess that the mounting brackets would need to be bent in order to get everything to line back up? If you havent noticed, and if youve seen my other projects, im pretty ocd when it comes to things lining up. Gaps make me
Old Sep 18, 2014 | 04:05 AM
Terrys87's Avatar
I would say the mounting bracket is bent as well. Replacing it is easy to do. Dont see where you are located but those are fairly easy to find.
The end caps will eventually come off. I use carriage bolts about the same size as the bumper bolts and remove the tab that is glued on and run the bolts thru the center in the back side of the caps. It looks like it could of come from the factory this way and they are never going to come off again. I have lost Toyota and aftermarket end caps on the road and this is how I fixed my issues. This is an old picture and I have it algined and painted but the only one I could find right off.
Old Sep 18, 2014 | 05:43 AM
Badger62811's Avatar
If the bumpers themselves aren't damaged, you should be able to use a BFH and some muscle to get the brackets straightened back out. Looks like a nice runner. More pics!
Old Sep 18, 2014 | 10:53 AM
Juke's Avatar
Terry, you mention the mounting brackets are easy to replace, not bend. So this is something i can buy a replacement part for and bolt everything right back into place? If thats the case and it will all align properly without any other work then i should have nothing to worry about. Please correct me if i misinterpreted that.
And badger, unfortunately from the pictures it looks like both front and rear bumpers are damaged. But i always keep a bfh not too far away for situations like that!
Jake28296
Jun 27, 2015 07:24 AM
Niameyrider
Jun 25, 2015 05:50 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
TheManOutside
Jun 18, 2015 03:32 PM
