Basket brake job
Old Sep 16, 2014 | 11:38 AM
c east's Avatar
Basket brake job
Friend "Fix" my brakes on my 1988 4X4 4 cyl fuel INJ..Toyota 148K Miles...He replaced every part...Now there are little brakes.....NEW....Front pads....New rear shoes.....New master CYL....New vacuum booster....New rear Wheel clyinders...New fluid...He has no Idea now why there are very little brakes.....
What would I expect to pay to get it all fixed...New everything....He put all autozone stuff...Took them 2 times to find the right master CYL...
Any chain you recommend?
Sorry Charlie
Old Sep 16, 2014 | 11:58 AM
Rerunn's Avatar
Man.... bleed the brakes
Old Sep 16, 2014 | 12:12 PM
JasonYota's Avatar
X2. Sounds like your "friend" shouldn't be allowed near a vehicle with a wrench
Old Sep 16, 2014 | 12:13 PM
millball's Avatar
X2- X2!!
Might to be necessary to remove the master cyl and bench bleed it.
If there is no air lock in the master cyl, the rest of the system can often be gravity bled.
Old Sep 16, 2014 | 12:42 PM
c east's Avatar
Neck injury left no feeling in my hands..Had an opoertaion in Aug and now "May" have feeling back in 1.5 to two years.....If I can throw $1200 at this thing and have it working This month...It would be worth it...I love this truck and I am sorry I let some less than knowledgeable work on it..If I have to I'll take it to toyota and Take a loan...Charlie
Old Sep 16, 2014 | 12:45 PM
millball's Avatar
If all the new parts are correct and not damaged, I would think any competent mechanic
should be able to make it right for a couple hundred $$., Maybe less.
Old Sep 16, 2014 | 02:26 PM
Gevo's Avatar
bleedingbreaks should cost you $60 at the shop. max. That's probably all you need as many already posted above.
If it works, you take your $1200, subtract $60, divide the rest up by all the people on here who told you to bleed your breaks. Deal?
Old Sep 16, 2014 | 02:43 PM
wyoming9's Avatar
Red face
You do use your Emergency Brake that keeps the rear shoes adjusted?
Then maybe the rear shoes were not adjusted
If they are out of adjustment your pedal travel gets worse the more you drive it
Could also be the pressure causing the hoses to balloon
Do you have any other friends that could help??
I would think any one doing brakes would know enough to bleed things but who knows.
I really lean towards the rear brakes not adjusted.
Old Sep 16, 2014 | 03:34 PM
dropzone's Avatar
Fossilized
The LSPV also needs tobe bled. It is connected to a rod from the axle to a mount on the frame above right side of the axle
Old Sep 16, 2014 | 05:45 PM
peabody's Avatar
Rear brakes out of adjust
Even if I worked on brakes during the year, I have mechanic at yearly inspection adjust rear brakes since they need to look at one anyway. Those arms going through the backing plate seize up especially if what wyoming9 asked first. But, what were the conditions before the basket brake job?
Old Sep 16, 2014 | 11:29 PM
wyoming9's Avatar
Red face
I have yet to bleed a LSPV only because I have never been able to get the bleeder fitting to break loose.
My one attempt one a friends vehicle cost me a new valve.
Old Sep 17, 2014 | 05:02 AM
c east's Avatar
The breaks were good...One day the brakes went much further before applying..I figured master Cyl worn.. He kept just throwing parts at it...The two rear brake cLys were seeping.....Charlie
Old Sep 17, 2014 | 05:33 AM
Gevo's Avatar
Let us know what happens after you bleed and adjust your rear brakes.
Old Feb 26, 2015 | 02:32 PM
c east's Avatar
It was on air bubble in the Master cly...Forced fluid in the Outlet and braked were better right away...Bled all slaves again no better but not bad brakes at all
Old Feb 26, 2015 | 04:55 PM
fasterspider's Avatar
I need to bleed my new brakes.
Old Feb 26, 2015 | 05:33 PM
bswarm's Avatar
^ Nice shocks! I have them also.
Old Feb 27, 2015 | 06:52 AM
$52.00 for the pair is all they cost me NIB.
kgcwb44
Jan 29, 2023 10:02 AM
jasonty
41
Dec 23, 2018 01:00 PM
Medic22733
Aug 10, 2015 06:49 PM
Sr5crawler
Jul 31, 2015 12:32 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
