Turn signal/Brake light flash
Old May 26, 2014 | 12:15 PM
RecklessWTx's Avatar
I recently pulled the bed on my 93 pickup to change the shock mounts. After bolting the bed down, the turn signal lights both flash when i turn the signals either direction on. Even the brake lights flash untill i press the brakes, then they all stay on. When I press the brakes, both blinker indicators illuminate. Checked the bulbs and sockets. checked grounds in the back. I can unplug both tail lights and still flash the same. I cant find a good diagram for the rear lights. Ive looked at both the FSM and this website for hours. Any help is appreciated.
Old May 26, 2014 | 12:47 PM
wyoming9's Avatar
Have you checked for pinched wires
I am guessing all was good to you pulled the bed off
Welcome to Yota Tech!!
Old May 26, 2014 | 12:52 PM
Finally isolated the wires. between cab and bed somewhere.
Old Mar 31, 2016 | 07:37 AM
trevdawg's Avatar
bringing this back!!
i bouhgt a truck and it has this problem. My turn signals are fine, but when i press the brake everything flashes. If i am not using the turn signals and hit the brakes, the brake lights flash like crazy.
The wires look fine but i am going to look more careful this time. Mine doesn't have the trailer harness either, which seems to be the problem most of the time.
Old Mar 31, 2016 | 12:50 PM
wyoming9's Avatar
Red face
Explain Flash like Crazy ??
Did you mean blink like a flasher in the Circuit ??
Flash on and off in a Random pattern ??
Sounds like a poor connection
Corroded connections
broken wires
Old Apr 5, 2016 | 09:49 AM
trevdawg's Avatar
Thumbs down
broken wires
flash like crazy
- right turn signal on and it blinks fine. hit my brake and then both of my turn signals flash and the brake lights in a random pattern.
(can't recall if my reverse lights light up too)
- not using turn signals, hit brakes and the brake lights flash erraticly.
i bought a can of that "electrical connector" cleaner and i sanded some rust off of a few contacts. most were good.That didn't seem to make a difference because the issue was still there.
The tailights are rusty on the back side, and the lens & seals are damaged any ways so i just bought new tail lights. I bought a pair of tail lights from some one over seas, on ebay, so i have to wait 3 to 4 weeks before they arrive.
i will have a 3.8 powered truck hopefully before the taillights even arrive.
Old May 18, 2016 | 06:12 PM
trevdawg's Avatar
I disconnected the pigtail in the cab, and tested all the wires. From behind the dash leading to the pigtail. Everything seems good except a yellow/blue wire. It is always hot. I was using a test light and when the bulb was always lightly lit. And when I touched the light to it, the low fuel light would go on . . . Wired.
Old May 25, 2016 | 07:36 PM
RAD4Runner's Avatar
Originally Posted by trevdawg
...except a yellow/blue wire. ...
Maybe that yellow/blue wire is supposed to stay hot.
Got schematic?
Got multi-meter?
A problem well-stated is a problem almost solved. If you told us what truck model year you have, someone could share a schematic with you so you can more effectively troubleshoot.
Old May 26, 2016 | 07:31 PM
horunner1x's Avatar
This happened to me. One of my bulbs melted and the brake filiment melted and touched running so when I hit my brakes my running lights and front turn signals lit up. Check the bulb filiments
Old May 26, 2016 | 07:32 PM
horunner1x's Avatar
Wait, edit. I wired my running lights to blink. That's why the blinkers lit up too.
Old Jun 3, 2016 | 08:17 PM
trevdawg's Avatar
It probably should always be hot but it seems weird how it lights up the low fuel light every time I touch it.
I do have a Haynes manual and the schematic seems hard to read. It only shows a blue/yellow wire briefly at one spot. I do have a multimeter but haven't been working on the truck. I have been traveling for work a lot so when I'm home I cleaning and cooking . . . Catching up.
I bought new tail lights off of eBay they shipped from Thailand. Not directly the same plugs but clean.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sleaker
Aug 26, 2020 06:03 AM
Shoua
13
May 22, 2016 05:19 AM
rushw
Jul 18, 2015 01:46 PM
Odin
Jul 15, 2015 09:28 PM
