Red oil light turns on when accelerating.
Old Apr 16, 2014 | 05:12 PM
ClintonP929's Avatar
When I accelerate in my truck the red oil light thingy turns on for a second and goes away until I step on the accelerator pedal again. I should also mention I can only see it when in low light, like its hardly on? If that makes a difference. The truck doesn't leak or burn any oil either, haven't touched the oil since I bought it a month ago. (Note: I didn't know of this when I purchased it, I test drove during day and couldn't see the light).
Also, I feel as if the truck has a lack of power, unless these trucks just are generally underpowered and that's how its supposed to feel I don't know, probably connected to the problem above.
Any thoughts?
Its a '89 Toyota Pickup
Old Apr 16, 2014 | 08:28 PM
the171's Avatar
you might have an oil pressure issue. The light coming on as you suggested is a sign of early bearing or oil pump failure. i believe the light comes on at around 7-10 psi which is very low. if so this is a major problem with the motor, i would shut it down and investigate before the engine becomes caked in metal shavings. oil pressure gauges are mandatory in older vehicles imo.
Old Apr 16, 2014 | 10:53 PM
wyoming9's Avatar
Red face
If the light is very dim not as bright as when you turn on the key prior to starting.
I would say you have something grounding back through the circuit lighting the light
Some place you might have a loose ground moving when you step on the throttle.
For peace of mind it would not hurt to check with a pressure gauge.
Depends just what you are comparing it to as for being under powered.
Old Apr 17, 2014 | 04:44 AM
Rerunn's Avatar
Check the connection at the oil pressure switch
Old Apr 17, 2014 | 06:46 AM
HighLux's Avatar
As cheap as they are...order a new pressure sensor....make sure to get the right one....one type for idiot light...another type for actual gauge.
I kinda like to know for sure what my oil pressure is doing....so...get on that...takes 5 minutes to replace.
bigjstang
Jun 2, 2025 03:56 PM
ashersullivan88yota
Jan 18, 2022 05:37 PM
coryc85
Sep 9, 2015 06:24 AM
smiley52
Jul 11, 2015 05:16 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
