General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
on my 87 pickup the right headlight dim
Old Mar 19, 2014 | 06:43 PM
longhorn717's Avatar
So i've been returning my pickup to driving condition and the right headlight is dim and when i unplug the left headlight they both go off. I was going to switch them to see if it was the bulb but when they both went off with it unplugged. I thought I'd ask y'all what you thought the issue was. Do you think I got a defective headlight or is there a problem with the truck?
Stumped in Texas
Old Mar 19, 2014 | 11:01 PM
wyoming9's Avatar
Red face
Check your plugs and the wiring .
It sounds like some one had problems and is running both lights off the one side.
Old Apr 1, 2014 | 03:54 AM
RAD4Runner's Avatar
Those are symptoms of ONE busted headlight fuse.
Those are symptoms of ONE busted headlight fuse. If you check schematic, you would see see leakage current in pink causing the side with blown fuse to still light but dimly.
If you disconnect side with the blown fuse, the other side would still light normally.
If you disconnect side with good fuse, that side would of course turn off (LOL!), and you remove source of leakage current, so side with blown fuse also goes out.
This is a know and absolute fact that Toyota headlight wiring is poorly designed.
Not an April's Fools joke.
Old Apr 1, 2014 | 09:15 AM
Hey thanks for that! I did however already solve that issue. Friend of mine came over and diagnosed it with a voltmeter. Couldn't tell the fuse was blown by looking at it! Lol I checked it before I even posted.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
