water pump replacement on 94 T100
is there a schematic or diagram for the proper installation anywhere online? I assume u have to pull everything by looking? was quoted 1100 by repair shop, can i do this myself easily?
Assuming it is the 3VZE (V6), look for protocols on changing the timing belt. Typically you will want to change water pump and timing belt at the same time, since both are in the same place and a huge PITA to get to.
Nothing about the job is hard, except maybe getting the crank bolt off. It is very time consuming, hence the huge labor charge.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
