Bolt snapped! HELP!
Old Mar 8, 2014 | 02:28 PM
twcolo's Avatar
Bolt snapped! HELP!
I was redoing this gasket when I accidentally overtightened upon completion. The bolt that is circled snapped off and unlike the front one doesn't seem to be able to be removed? Unless I am doing it wrong? I was hoping that someone else may possibly have gone through a similar mistake or repaired this and known how to remove the bolt... If not, what is the best way to keep the area secured once the gasket cures?
Thanks....
Old Mar 8, 2014 | 02:35 PM
Polaris2012's Avatar
Not for sure but I'd think if the front bolt comes out the back would too. Did it break off flush? Or is it just broke off on the top? I think it is threaded into the other end.
Old Mar 8, 2014 | 02:36 PM
twcolo's Avatar
clean break, i attempted an extraction kit and had no luck....
To be more clear, it broke at the center of the stud, where the nut would stop after being tightened... not all the way down to the base.
Old Mar 8, 2014 | 02:38 PM
Drill it out and use a tap
Old Mar 8, 2014 | 02:40 PM
If try using vise grips or something like that and try to thread it out. I can't imagine it's welded on there.
Old Mar 8, 2014 | 02:42 PM
twcolo's Avatar
I just want to make sure before I try that it is, in fact, removable... then I will go to extract it a bit more aggressively...
Old Mar 8, 2014 | 02:44 PM
If you have a welder you could thread a bit on there and tac it. I'm not 100 percent sure if it is.
Old Mar 8, 2014 | 02:53 PM
twcolo's Avatar
Unfortunately I do not have a welder...
Old Mar 8, 2014 | 02:54 PM
wyoming9's Avatar
Red face
Get some good penetrating oil Kroil if you can .
Soak it good over night perhaps spray it before you go to bed or after you come home
If you can get it out your fine and good to go.
Work it to the right first then to the left don`t get real crazy steel in aluminum always corrodes .
If you do have it break off be careful drilling it out drill bits love to drift into the soft aluminum.
Use the thread insert of your choice M8x1.25 thread
thermostat bolts break all the time
Old Mar 8, 2014 | 02:56 PM
twcolo's Avatar
Thank you for this... I'll run to Autozone shortly and buy some... I'll soak it overnight and go at it in the AM with some vice grips...
Old Mar 8, 2014 | 03:32 PM
twcolo's Avatar
BEHOLD THE BEAST!
Thank you guys so much!
Old Mar 9, 2014 | 12:46 AM
wyoming9's Avatar
Red face
Glad you got it out without having to drill.
make sure to never seize the nuts on your new studs
Old Mar 10, 2014 | 08:59 PM
nv4runner's Avatar
Those two studs have to come out to remove the upper timing cover. Glad you got it out!
wberry85
Apr 6, 2018 08:45 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
Pocoyota
Sep 8, 2015 02:41 PM
Jwp1
Sep 6, 2015 11:03 AM
Ryall
Sep 2, 2015 06:48 AM
