Engine Starts, but stalls after two seconds.
Let me explain my situation. I recently adjusted the valves on my 1994 toyota 4runner with a 22R-E engine. I got it as my first car a little over a year ago and the valve spacing was horrendous so i finally decided to do something about it.
After I adjusted my valves to the specifications recommended by my hanes manual (.3mm exhaust and .2mm intake) I put the engine block and vacuum hoses back on and tried starting it. It started instantaneously, and when it runs it sounds fine. But the engine won't stay running for more than 2 seconds. even if i step on the throttle. The hanes manual suggests my problem is the vacuum hoses that are the issue but i'm pretty sure i have mine plugged into the correct spots. The other thing i was thinking it could be is the fuel pump so i plan on checking that when i get the chance.
Anyways, I was just wondering if anyone else has had this problem and could give me advice in case i'm looking for the wrong solution. Also if anyone has a Vacuum hose wiring diagram that they are willing to share, that would be nice as well.
This 4runner is my daily driver so i want to get it up and running ASAP.
Like TerryS says, it sounds like the Air Flow Sensor on your air filter housing isn't connected.
The fuel pump runs while the iginition key is in the Start position but relies on air flow to keep it on while in the Run position.
94 Newbie
Jul 6, 2015 04:23 AM
