No oil pressure after oil change.
I recently changed the oil on my 1994 4x4 22re pickup and come to find out the previous owner hasn't changed the oil since god knows when. I now have no oil pressure but when I drive it I don't hear any unusual noises coming from the top of the engine. I'm fairly new to this so could y'all spell it out for me?
If you changed the filter, you probably hit the oil pressure sender, and knocked the plug loose. Just below and rear of the the filter. (22RE) check that first. The stock gauges aren't the most accurate for readings, but it should show something unless unplugged or gauge burnt out.
It just slides over the top of the button, parallel to the block, if you have a gauge. For an idiot light, it goes on the blade, at 90* to the block.
Maybe you could modify a female blade to fit over the button? It should have a harness connection 4-6" up the wire, you may find a whole new end in a JY or somewhere.
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
