Sponsored by: CARiD
No oil pressure after oil change.
Old Feb 27, 2014 | 08:06 PM
jsmith92's Avatar
I recently changed the oil on my 1994 4x4 22re pickup and come to find out the previous owner hasn't changed the oil since god knows when. I now have no oil pressure but when I drive it I don't hear any unusual noises coming from the top of the engine. I'm fairly new to this so could y'all spell it out for me?
Old Feb 27, 2014 | 08:22 PM
rokblok's Avatar
What are you basing "no oil pressure" on? Have you actually tested for oil pressure readings, or are you relying on a gauge in the cab?
Old Feb 27, 2014 | 08:37 PM
combatcarl's Avatar
If you changed the filter, you probably hit the oil pressure sender, and knocked the plug loose. Just below and rear of the the filter. (22RE) check that first. The stock gauges aren't the most accurate for readings, but it should show something unless unplugged or gauge burnt out.
Old Feb 28, 2014 | 10:15 AM
jsmith92's Avatar
I'm basing no oil pressure on the stock gauges. They worked fine before the oil change. I'll definitely check the sensor.
Old Feb 28, 2014 | 10:33 AM
jsmith92's Avatar
Size:  56.5 KB. Is that the broken sensor?
Old Feb 28, 2014 | 11:13 AM
combatcarl's Avatar
Yep. Looks like the wire lost the clip.
Old Feb 28, 2014 | 11:20 AM
jsmith92's Avatar
What would be an effective fix for it?
Old Feb 28, 2014 | 11:44 AM
combatcarl's Avatar
Well, it's a funky square clip that goes onto either type of sender. Lemme get a pic of mine so you can source one, or engineer a temporary fix.
Old Feb 28, 2014 | 11:53 AM
combatcarl's Avatar
It just slides over the top of the button, parallel to the block, if you have a gauge. For an idiot light, it goes on the blade, at 90* to the block.
Maybe you could modify a female blade to fit over the button? It should have a harness connection 4-6" up the wire, you may find a whole new end in a JY or somewhere.
Old Feb 28, 2014 | 11:59 AM
jsmith92's Avatar
Alright. Thanks for the help! I greatly appreciate it.
Old Feb 28, 2014 | 12:04 PM
combatcarl's Avatar
No worries. I know how nuts no oil pressure indication makes me. My sender isn't working. Haven't found one in a yard yet, ain't payin $70 for a new one...
Old Feb 28, 2014 | 12:05 PM
Inferno451's Avatar
You can modify a standard female crimp on connector to work. Enlarge the slit in the bottom and it should slide right on.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
