Tires and lift
Tires and lift
So I'm a newbie and this has probably been asked a million times but I'm getting new tires and wanted them to be a bit meatier and the ones I have on now are getting to be pretty low and they are already hitting the fender wall , I'm up for a lift but funds are tight right now and I need new tires but am also open to lifting but don't wanna lift and have little tires any help is much appreciated .
Are they stock rims or aftermarket rims? 31s shouldn't be rubbing if you have stock rims. Also, 225/75/15 is not a rim size. It's a tire size. If you read that on the door sticker, that's the factory tire size. Rims are usually measured like 16"x8". 16" being the diameter of the rim, 8" being the width, for example.
Oh I'm sorry . Yeah I don't know much about tires at all . 31.10.50R15 is what it says and I believe they are stock rims but have no idea . I do know that they do rub on my wheel wells and it makes it kinda hard to turn because they are always hitting the walls . It is from 91 so there is a little squat and I wanted to try and fix that as well with the lift but just don't want to lift and have tiny tires and end up flipping over and don't want to get too big of tires and end up not even being able to drive at all because they would be too big ..
First off post some pictures of the 4Runner. Ones that show the wheels and fenders would really help. If 31's are rubbing something is going on that shouldn't be.
As for lift... Read this https://www.yotatech.com/forums/f116...-thread-41616/
This should answer most if not all of your questions.
You can do some trimming inside the front wheel well to help with the rubbing:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
i could see how Toyo MTs will rub when a stock size "should" fit, the side lugs are huge on those tires, I have some on my truck. like stated already, it's also possible you have aftermarket wheels on your truck - so first figure that out. also, it's possible someone touched the t-bars in the front and it's sitting too low - what is your distance between center of axle to bottom of fender lip?
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
