Pre 84 Trucks 1st gen pickups
tranny info. location.
Old Dec 5, 2013 | 05:25 PM
chrisgreene243's Avatar
Just picked up an '81 4x4 and looking to get a new top cover for it. Vin plate says its an L52 but is there any info stamped on the transmission itself that would verify this?
Old Dec 5, 2013 | 05:31 PM
dropzone's Avatar
Fossilized
no there is no stamp or anything..
does it shift through 5 gears?
Old Dec 5, 2013 | 05:41 PM
Not that i could see from underneath the truck. And i believe its only a 4 speed
Old Dec 6, 2013 | 06:16 AM
83's Avatar
83
I think all the 4-speeds have a side shift. As in the shifter from your cab connects down to the side of the tranny. In 5 speeds, the shifter connects down to the top center of the tranny.
Check out Marlins site for identifying them by sight. http://www.marlincrawler.com/transmi...built-complete
Kind of looks like the very last 4 speed trannys look a lot like the L series 5 speeds...
Old Dec 6, 2013 | 06:17 AM
83's Avatar
83
Can you shift through 5 speeds?
Old Dec 6, 2013 | 09:40 AM
Thanks for the link , and no fifth gear.
Heres some half@$$ pics.
Old Dec 6, 2013 | 10:49 AM
83's Avatar
83
Yikes!
Doesn't look like an L52 shift fork.
Whatever it is, it needs work...
Old Dec 6, 2013 | 11:09 PM
Yep ive got 1st through 4th gear but reverse is where fifth should be. Which is where i got the idea of it being just a 4speed.
Old Dec 7, 2013 | 02:24 AM
dropzone's Avatar
Fossilized
L43 is side shift. L45 is a 4 speed that externally looks like a 5 speed L series
Old Dec 7, 2013 | 05:48 AM
gillesdetrail's Avatar
That looks like my L45 4 speed (if you say it doesn't have fifth)
Old Dec 7, 2013 | 07:12 AM
I was able to find this guy stamped on the driver side.
Old Dec 7, 2013 | 07:21 AM
83's Avatar
83
Doesn't really matter...you've got an L45 based on what people are seeing. That stamp probably has nothing to do with the tranny model
Reverse is up and to the right??? I doubt it. If reverse isn't right next to 4th, but instead right next to 3rd, there's something very strange going on!
You can put an L50 or L52 into your truck with no modifications.
At some point the tranny went out, and previous owner was able to find a cheap, used 4 speed, so they put it in.
Old Dec 7, 2013 | 07:41 AM
Yea they hacked away at the floor pan to do some sort of modification to it. But for an '81 with a solid front axle and a rebuilt 22r under the hood i think i getting it for $750 wasnt too bad.
Old Dec 7, 2013 | 09:30 AM
83's Avatar
83
Also the plate on top that the shifter goes into is obviously cracked. Easy for dirt and water to get into the transmission.
But I agree! That's a good deal.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
