87 Pickup Rear Axle Assembly Removal as Whole Unit
Hello fellow Toyota enthusiasts...
I've got an 87 Toyota 22r 4x4 pickup and I'm currently replacing the front rotors, calipers, bearings, seals, gaskets and brake lines. I was also going to replace the rear brake lines to the proportioning valve. I knew going in that the drum brake backing plate was very rusty along with the lines and fittings.
My question is: can I remove the entire rear axle assembly with the drums attached so that I can easily remove the rusty fittings / bleeder plugs and then clean off the rust and paint. I've searched yotatech and the web for an answer to this question and all of the hits were related to rear bearing and seal replacement and did not specifically address my question. I'd rather not replace the bearings and seals at this time (funds were spent on the front end) and just clean up the rust, reinstall the axle shaft and replace the bleeder and the brake lines with new brass fittings.
Can the assembly be removed or am I completely missing something that is lurking behind the drum to successfully remove the rear axle shaft?
I appreciate everyone's time in advance.
Well you can remove it but it takes some work.I have never been able to get U Bolts off So you need them .
E-Brake cables off the rear end housing
Brake lines
LSPV Hardware
Drive Shaft making sure to mark the drive shaft.
No doubt forgot something
Sorry if I was not clear - I was considering leaving the differential carrier in place along with the leaf springs an shocks. I was trying to determine if I could pull the brake drum / hub and axle shaft out in one piece by removing the 4 bolts behind the drum dust shield (as if I was going to replace the bearings).
Like the picture attached but with the drum still attached and the parking brake and brake lines disconnected. From the thread I got this pic from the person mentioned gear oil with the differential carrier. I guess I should read up on that as well.
Yes, take brake lines off, 4 bolts the backing plate and away you go, you can leave your tires on if you want to. Put some rubber tips on your brake lines so they don't leak all your fluid out.
6th Gear
19
Dec 10, 2019 07:31 AM
cchinny
Jun 25, 2015 08:11 PM
Leonel
Jun 13, 2002 02:42 PM
