Rear window won't go up
took my top off for about a month. Put top back on minus a few top bolts I couldn't line up and now rear window is not working. Couldnt find which fuse controls the rear window. Help!! It's cold outside!!
Clairvoyant....lol had to look that one up. Yeah that was on oversight of info that might be useful.
1986 4runner
No other electrical issues. And this is the first time the back window has given me any trouble
1986 4runner
There is quite a few safety switches .
Did you remember to plug the cover Top switch in that will not allow the window to go up with the top off.
The wiper safety switch will also do the same thing.
If you thought that did not need to be plugged in as well .
One or both those safety switches is more then likely your problem.
This gets power from both the 20amp Power window Circuit breaker and the 15amp engine fuse both behind the left kick panel
The wiper switch is the plug over by the left panel corner and tailgate where the fluid host goes up. Correct? I put that one in. Did not notice a top switch that you mentioned. Don't remember unplugging it either. Where would that would be? Thank you
Finally figured it out. The "cover top switch" requires the bolt for the top to be inserted for the truck to know that the top is on and ok for the window to go up. U can see an actual picture of it in the color picture. It's the box looking piece at the top that runs directly under the second to last bolt on the driver side.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
icentropy
Jul 14, 2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
