wont start unless i pull the negative battery cable first?
I am having a problem with my 95 yota pickup where I have to pull the negative battery cable for at least a minute before it will start. even if i just had it running. also if i stalled it out, then bump started it, it will fire right up. any ideas on why it would be doing this? i am lost..
battery is good, alternator is also good . it just seems i have to reset somthing before it will turn it over with the electric start
I am not sure on the system part. This truck is 100% new to me, i bought it not running with a bad motor, put a motor in it and am now facing this problem lol. it was sunk in about 3 ft of water and sat for 5 months as is before i got it
If this does not have a Alarm
I would almost guess your problem is having bad grounds .
i am not sure what this bump starting is??? Does it involve using or threatening with a real big hammer??
In this condition you have no electrical power at all??
Lights work, radio etc??
Engine does not crank??
Engine Cranks but does not start??
are we dealing with a manual or auto??
Every electrical connection is now suspect. If you get it running, you should be prepared for it regularly dying without warning.
Please, please, don't try to sell it unless you disclose that it sat in water for 5 months. Better yet, don't try to sell it at all.
Pulling the wire resets the CPU and the diagnostics. There's a lot of sensors that correct only after two starts. So it'll run on factory setting the first, then adjust when you go to start the truck again. I have no idea which one it might be... that's a wild goose chase.
I have a complete parts truck that i have been stealing parts off. so far i have stole the computer out it but no luck. I am going to try to replace the negative battery cable next but i doubt that will work. what else could i try and replace?
I dont plan to sell it, i have way to much money into them now haha
Anyone? Btw the truck wasnt sunk and left in the water for 5 months lol it was sunk, pulled out and left for 5 months. I finally got it running perfect now, just this is my only problem stopping me from putting it on the road
Team420
Jan 12, 2021 04:57 PM
alfonz33
9
Nov 16, 2015 09:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
