My 22re is burning a lot of antifreeze?
Old May 29, 2013 | 08:11 AM
rydholm11211's Avatar
As soon as I start my truck it builds pressure in the radiator real fast , and has a lot of white smoke out the tail pipe, so I am pretty sure it is burning antifreeze? So I think It has a bad Head Gasket, but I did a compression check and got 180 psi across all four? So do you guys still think it is the head gasket? My plan is to buy a rebuild head, and change the head gasket and timing chain? And I think that should solve my problem? What do you guys think? thanks.
Old May 29, 2013 | 08:22 AM
snobdds's Avatar
Anytime you have coolant issues, your first test should be a coolant pressure test. A leak can be external to the combustion chamber and a compression test would show normal. But it does sound like a HG leak...
Old May 29, 2013 | 08:59 AM
How do you do a coolant pressure test?
Old May 29, 2013 | 09:10 AM
snobdds's Avatar
Plenty of write ups if you google it.
Then go to your local autoparts store and rent a tester if you don't have one.
RatOmeter
Oct 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
Jonny246
Jul 12, 2015 04:51 AM
