fuel pump assembly gone bad!
Old May 24, 2013 | 07:23 AM
hypermax's Avatar
I need a fuel pump assembly for my 90 yota and the dealer wants $250 for it, is their any sites or any other places to get one through that would be cheaper?, also a speedo cable seems lordco cant get eather
Old May 24, 2013 | 09:43 AM
scope103's Avatar
RockAuto has fuel pumps for $29 to $144. Only you know what you mean by "assembly."
Old May 24, 2013 | 12:32 PM
hypermax's Avatar
the assembly is the part that bolts onto the top of the tank and has your out let and reaturn line its also has the float and the plug on it as well
Old May 24, 2013 | 07:18 PM
Terrys87's Avatar
The fuel pump assembly comes in all different sizes. 2 and 4 wheel drives are not the same length and even different years. This one is 11 inches and 1/8th inch. It is missing the rubber gasket that goes in between the pump and holder on the bottom. I think it came out of a 92 truck should be the same but not sure. They are a little better price on ebay. Place an ad in the Parts Wanted section and you can find some thru there as well.
I dont see a part number on it, but this is where you really need to do your homework to make sure you get the right one. All of the years look similar, but the thing I see on them is the length from real short to even longer then this one. I compared it to an 87 4x4 pick up and this one is about an inch shorter then the 87.
Some Float Assembly differences. The one on the left is what you will sometimes hear as a 3 wire float. It is for the Low Level Fuel Light which is an option. As far as I know, they are interchangeable, just depends on whether you want the light or not. Flat electrical plug is for 86 and newer and the round electrical plug is for 85 and older if I recall right. I tend to stay in the 84-88 trucks so some of the information may be different for the newer trucks.
Copied...
Low Level Light Option and plug differences.
SR5 Guage Light
Non SR5 Guage Light.
Old May 24, 2013 | 09:36 PM
hypermax's Avatar
ok thanks so mutch im gonna try to fix mine and if its gone to far ill be posting a add
Old May 25, 2013 | 12:03 AM
wyoming9's Avatar
Red face
There is the fuel pump bracket that holds the pump.
there is also the sending unit.
just where do you live?/
Old May 25, 2013 | 08:56 AM
hypermax's Avatar
in nanaimo im gonna try to fix it and if i cant ill post a ad looking for one thanks guys
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Kluch8651
Jul 9, 2015 10:39 AM
