98 v6 spark plugs
What is your favorite set of spark plugs for the 98 V6runners?
I'm getting ready to tackle this.
How often should they be changed? and should they be torqued down or is snug good enuff?
Originally Posted by Mossback74
Dont some newer 4Runners have Denso on one head and NGK on the other from the factory(ies)
Yes, it's true. The passenger side uses NGKs and the driver side had Densos on my rig. I noticed it when I did the initial spark plug replacement. Since then I've replcaed mine with the NGKs. I'm going to try densos and ngk next time I replace the spark plugs. Hope this helps.
George
George
20 ft/lbs acording to Haynes.
If you plan on doing more maintenance on your truck, bite the bullet and get a torque wrench. You'll be needing it on other projects as well.
I am running NGK BCPR7ET (2 steps colder, per Gadget's recommendation on S/C engines)
Make sure you put anti-seize on your spark plug threads.
montanatruck
Feb 26, 2017 07:07 AM
defrag4
Jul 31, 2015 10:50 AM
