98 v6 spark plugs
Old Feb 16, 2004 | 07:02 AM
CUBERA's Avatar
Question 98 v6 spark plugs
What is your favorite set of spark plugs for the 98 V6runners?
I'm getting ready to tackle this.
How often should they be changed? and should they be torqued down or is snug good enuff?
Old Feb 28, 2004 | 12:38 AM
Mossback74's Avatar
Stock Denso's, torque to specs
Old Feb 28, 2004 | 01:05 AM
Tacoma Dude's Avatar
What he ^ said
Old Feb 29, 2004 | 06:56 PM
MTL_4runner's Avatar
Yep, same here!
Old Feb 29, 2004 | 09:53 PM
humanoid's Avatar
OEM seems the way to go according to most the folks on this board.
Old Feb 29, 2004 | 11:49 PM
X-AWDriver's Avatar
OEM or NGKs,they've never done me wrong.
Old Mar 1, 2004 | 03:28 AM
Mossback74's Avatar
Dont some newer 4Runners have Denso on one head and NGK on the other from the factory(ies)
Old Mar 1, 2004 | 10:41 AM
I have heard this, but I have never found evidence that it is true (other than this writeup ). Even if it was, there is such a subtle difference that you would never know the difference from one to the other plug (although Toyota was trying to save money on assembly). Also if you go to the dealer and ask for plugs they will never give you the 2 different sets of plugs. It is perfectly fine to just use either all NGKs or Densos in the engine.
Old Mar 1, 2004 | 04:58 PM
george16's Avatar
Yes, it's true. The passenger side uses NGKs and the driver side had Densos on my rig. I noticed it when I did the initial spark plug replacement. Since then I've replcaed mine with the NGKs. I'm going to try densos and ngk next time I replace the spark plugs. Hope this helps.
George
Old Mar 9, 2004 | 01:33 AM
Mossback74's Avatar
torque to specs
20 ft/lbs acording to Haynes.
Old Mar 31, 2004 | 01:28 PM
Sbrut95's Avatar
Okay, this may be a stupid question, but how do you know when youve torqued them down to 20ft/lbs if you have basic hand tools? Ive never changed my plugs before, but I was thinking I needed to. I thought they just plugged right in??
Old Mar 31, 2004 | 01:44 PM
If you plan on doing more maintenance on your truck, bite the bullet and get a torque wrench. You'll be needing it on other projects as well.
Old Apr 5, 2004 | 08:04 AM
SLC Punk's Avatar
I am running NGK BCPR7ET (2 steps colder, per Gadget's recommendation on S/C engines)
Make sure you put anti-seize on your spark plug threads.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
