22R temp question...
Old Mar 10, 2013 | 02:46 PM
MATTSRED's Avatar
Okay so my original temp gauge is stuck in the middle so I added an aftermarket temp gauge which reads in the thermostat housing right before where the thermostat sits.. So my question is it was running past 230 degrees to me that seems awfully high. I was cruising on the freeway about 60-65mph and it's probably 70degrees out... If anyone could shed some light on normal operating temps. 84 22R...
Old Mar 10, 2013 | 04:55 PM
ojm3's Avatar
Id say replace the temp sending unit. My guage was stuck maxed out i replaced the unit and it worked fine.
Old Mar 10, 2013 | 05:28 PM
suncomb1's Avatar
I agree with ojm3. I would also install a new 180 degree thermostat. Modify the new thermostat by removing the little pin in the plate and drill that hole out to 1/4". This modification reduces temperature overshoot on intial warm up.
Old Mar 10, 2013 | 06:06 PM
MATTSRED's Avatar
Good thing I live close to work. I'll hit up autozone tomorrow and see what happens when I install those parts.
Old Mar 10, 2013 | 06:55 PM
rworegon's Avatar
Results with a non-Toyota t-stat may vary. I'd stick with a new Toyota OE one.
Old Mar 10, 2013 | 07:04 PM
mightymouse's Avatar
this. best advise. Test it before you run it too please.
Old Mar 11, 2013 | 03:13 PM
ojm3's Avatar
listen to these guys I went through 3 thermostats trying to figure this out
Old Mar 18, 2013 | 06:05 PM
slow-mo's Avatar
And just to add to the OEM (22R) thermostat comment:
Toyota's temperature specifications are that the thermostat starts to open at 190° F, then fully opens at 212° F.
Old Mar 19, 2013 | 04:46 AM
piratelegs's Avatar
OEM or drill a hole in aftermarket. U can check ur thermostat by putting it in a pot of boiling water, if it opens tada
Old Mar 19, 2013 | 06:04 AM
ojm3's Avatar
I got a 180 from autozone and did a complete system flush and new temp sending unit. I've had no overshoot or temp problems. if you burp your system correctly and fill it entirely overshoot wont happen.
MadMax48
Mar 3, 2020 10:33 AM
coryc85
Dec 5, 2015 08:42 AM
Boomer8404
Sep 20, 2015 06:15 PM
--Oz--
Sep 6, 2015 01:06 AM
