Clutch Wont Disengage
Old Jan 15, 2013 | 04:15 PM
854x4's Avatar
Clutch Wont Disengage "FIXED"
Need some advise my 85 truck is having a problem where the clutch wont disengage and it almost stalls at stop lights unless I put it in neutral. I have replaced both the master and slave and have bleed everything (on the bench and truck) and its all adjusted. I checked the bracket and its not cracked. I think I have a problem with the pressure plate but would like a second opinion before I pull transmission.
Old Jan 15, 2013 | 06:42 PM
toyquad's Avatar
well since you ruled everything else out , sure its the pressure plate.
or there is still air in the system, it can be a bitch to bleed sometimes.
wouldnt be the first time a new part was faulty either.....
is the slave moving the clutch fork far enough? is the clutch fork cracked or worn out? seen that before too
Old Mar 28, 2013 | 10:30 PM
854x4's Avatar
I wanted to update this because I hate seeing threads without the fix. I removed the transmission and found that I was missing one of the two clips that hold the throw-out bearing to the fork so when I would push the clutch in only half of the bearing would apply pressure. I also decided since I was this far to replace the input seal and then I found my input bearing broken so I torn the trans apart and it looks good except for the chipped tooth on 5th gear but that will be a later fix.
Old Mar 30, 2013 | 07:44 PM
rokblok's Avatar
That's great that you gave a find and fix. Thanks for taking the time to let us know. Hopefully it will help someone in the future.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
