Piston Slap 1990 4runner 3vze Rebuilder Recomendations
I believe that my 1990 4runner 3vze has position slap. It starts up just fine, no noise at all, even on a 10 degree startup. After full warm up, when driving or not in gear or revving the motor, it makes a clacking sound at 2200 to 2800 rpm. Noise is not present above or below these rpm levels. Sounds exactly like when the Predator in the movie makes that clicking noise, same speed and sound level. Seems to make the noise more when at 2500 rpm when letting off the gas or coasting coming off the high rpm's with the clutch engaged.
My brother thinks it's piston slap. It has 210,000 miles. I just bought it not knowing it had the noise because I test drove when cold, it had no plates, so test drive was short and previous owner lied to me. It's not a big deal because I purchased at a low price anyway. It also passed smog.
I have been researching for a rebuilt motor, but can only find reputable rebuilders for the 22re. Posts for 3vze motor rebuilds are old. I don't have time to rebuild it myself. Anyone know of any good recommended sellers? I am located in Reno, NV but I am willing to buy and ship in.
if you can imagine the noise the Predator makes in the movie, it sounds just like that.
Because of the issues with a 3VZ-E when it ages (worked great brand new!), you won't find a whole lot of people rebuilding that type of engine. 3.4 swap is more common but more work, obviously, since you have to change a few things. If I had the time and money I'd consider it myself.
Anyone heard of this place:
http://www.yotashop.com/3-0l-toyota-...ed-long-block/
These are the only sites I have found:
http://raptorengines.com/index.php?m...l&disp_order=2
http://www.toyconnection4x4.com/
http://toyotaperformance.com/3vze.htm
http://www.doaracingengines.com/v6-engines.html
http://www.sunwestautomotiveengines.com/lb-toyota.html
DOA and Toyotaperformance are extremely expensive. Any recommendations on these or other rebuilders?
MMA_Alex
25
Apr 18, 2017 05:07 AM
jerusry
Oct 19, 2015 05:28 PM
