Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Sub installation option and system upgrade
Old Oct 15, 2012 | 06:19 AM
dvaldi's Avatar
95 4R Sub installation option and system upgrade
This is an example of a low-ish cost, under $500, audio solution that bumps up the existing factory system. I didn't want a sub box floating around taking up cargo space and screaming PLEASE TAKE ME! Since my installation, some components have been discontinued but I'm sure replacement components are available at equal or lesser cost. Clink link below to see pix.
New audio components:
Pioneer TSG1044 4" front speakers-$40 (these were blown, all other stock speakers still worked well)
Sony CDXGT820IP deck-$200 (powers tweets and mids)
Rockford Fosgate Punch Amp P325.2-$100 (powers sub)
Kicker Sub CVT651-$70 (this was the lowest profile sub I could find that fit within the existing space)
Misc. wire and materials-$60
https://plus.google.com/photos/11829...CLvTkLCel7GfXw
Old Oct 15, 2012 | 07:04 AM
Outsane's Avatar
nice work on the install....
I wasn't able to find enough room to fit a box in the 1st gen.
Old Oct 16, 2012 | 09:16 AM
dvaldi's Avatar
Thanks man...for those interested in box dimensions, I didnt measure the finished size but I might be able to get them without ripping my interior apart.
Old Oct 16, 2012 | 10:23 AM
RAD4Runner's Avatar
Love the Minimalist Approach
Originally Posted by dvaldi
This is an example of a low-ish cost, ... I didn't want a sub box ... screaming PLEASE TAKE ME!
I like this, especially the sub-install! I'd like to do similar on my first-gen. Just wanna keep afer-market HU that came with truck, and possibly add:
  • A sub driver that's thin enough - enclosure would
  • Amp for the sub
dvaldi Thanks for sharing! Would appreciate your observation on how much bass you get from the sum-amp combo.
  1. Is it just enough to hear/feel clean bass above road noise, or
  2. is it plenty so people outside can hear what you're listening to?
TIA
Old Oct 16, 2012 | 11:19 AM
dvaldi's Avatar
Thanks RAD, the lowest profile sub available at the time is listed above including the amp. This is a good link for the latest Kicker sub specs... http://www.kicker.com/CompVT_CVT651. Looks like you can pick one up from Best Buy. According to the specs, you will need a mount depth of 3" + 1" (enclosure 1/2" OSB X2) for a total depth of 4". I gained an extra 1/2" by cutting a hole in the back enclosure panel and glued/screwed a thin steel plate to seal the back panel hole. This reduced the overall depth to 3 1/2" but the sub itself is proud by about a 1/2". SOOOO, 4" total vs 4 1/2" to clear the OEM plastic cover plate. 1/2" made all the difference for fit/finish. Its a 6 1/2" sub, does a great job but certainly not a 10" or 12" boomer. You can hear it outside the car and it also vibrates my rear view mirror. Just a nice clean thump.
Old Oct 16, 2012 | 11:52 AM
RAD4Runner's Avatar
... I gained an extra 1/2" by cutting a hole in the back enclosure panel and glued/screwed a thin steel plate to seal the back panel hole. This reduced the overall depth to 3 1/2" but the sub itself is proud by about a 1/2". SOOOO, 4" total vs 4 1/2" to clear the OEM plastic cover plate. 1/2" made all the difference for fit/finish...Just a nice clean thump.
Clean install! Yep, just a clean thump is all I need.
Thanks a lot & Regards,
RAD
Old Oct 16, 2012 | 12:22 PM
dvaldi's Avatar
I cant get to the sub box without removing interior panels...BUT...this will help you tailor the size of box specific to your vehicle.
1.Check to see if you have a minimum of 4" depth behind interior plastic side trim panels.
2. Kicker CompVT CVT651's require a minimum sealed box volume of .2 CU/FT or 346 CU/IN.
3. Measure available H and W in your rig, leave some space to maneuver box into place.
4. Start doing the math, multiply your inside box height and width dimensions by 2.5. This is the minimum depth needed to accept the sub (this includes cutting a hole the back panel). i.e. 14"Hx10Wx2.5"=350 CU/IN or 15.5"Hx9"Wx2.5"=348 CU/IN and so on...
5. I constructed my sub box using 1/2" Hardboard or Masonite. 2.5" top, bottom and side panels with front and rear panels screwed/glued to the 1/2" face. If properly constructed, you will end up with a box size of H?xW?x3.5"D.
Old Oct 16, 2012 | 02:24 PM
RAD4Runner's Avatar
[COLOR="Yellow"]1.Check to see if you have a minimum of 4" depth behind interior plastic side trim panels....
Sweet! Thank you so much, dvaldi
insane,
If you ever decide to go this route, let's compare notes. I'm in S.D., too.
Old Oct 16, 2012 | 06:42 PM
dvaldi's Avatar
You are welcome....What happened last night RAD? Manning looked like his old self, or maybe it was Rivers problem. I know this is "off topic" but had to raz you guys! Cant say much with Detroit as our only hope.
Old Oct 16, 2012 | 07:08 PM
iamsuperbleeder's Avatar
nice clean install!
I have a single Kicker CVT 10 in my double cab 06 Taco, and that one little sub is RIDICULOUS for a single 10; I love it
Old Oct 17, 2012 | 12:41 AM
RAD4Runner's Avatar
LOL! yeah. I don't follow football but heard about that upset. Crazy!
Originally Posted by iamsuperbleeder
nice clean install!
iamsuperbleeder, what amp do you use with your 10"?
Old Oct 17, 2012 | 09:07 AM
Outsane's Avatar
Sounds like a plan..
I wasn't able to find enough room... I am using an Elemental Designs slim 10" I built a sealed box for
Old Oct 17, 2012 | 01:11 PM
dvaldi's Avatar
fancy schmancy! pocket holes, bull nose edges....nice touch.
Old Oct 17, 2012 | 01:30 PM
Outsane's Avatar
thanks
Old Oct 17, 2012 | 02:36 PM
A cheap Sony Xplode 1000 watt amp. Puts out closer to 800 watts max and 400 watts RMS on a single bridged channel and that's what I'm running it on; that's actually what the sub is rated at, and I still have to have the gain set at about 60% or I get distortion...
Old Oct 21, 2012 | 05:32 PM
BiggieD's Avatar
I really like the install Im curntely working on something very similar in my 95 . The one question i have is where did you install your amp?
Old Oct 22, 2012 | 04:37 AM
dvaldi's Avatar
BiggieD, Under the passenger side front seat.
Old Oct 22, 2012 | 05:44 AM
BiggieD's Avatar
alright cool i was thinking either that or maybe even in the otherside in that little cubbie hole .
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 17, 2015 10:13 AM
bryan34w
Jul 6, 2015 05:53 PM
Vargntucson
Jul 4, 2015 12:15 PM
