Cold Start Injector Test
Old Sep 4, 2012 | 03:42 PM
A2theK's Avatar
I'm running very rich and thinking my cold start injector may be stuck open. Probably a fairly easy question but just wanted to make sure. Will I be able to unplug the injector at operating temperature when it's running rough to see if that will clear up my issue? Is this a way of testing the CSI?
Old Sep 4, 2012 | 05:31 PM
scope103's Avatar
That will tell you if your CSI circuit failed in a way to provide current to the injector. It's an unusual failure, but there's no harm in doing that test.
A more likely failure would be the injector stuck open, so that it is leaking fuel even with no start signal. (I don't think this is common, just more common than a signal failure.) You could test that by pulling the injector out, and then running the fuel pump by jumpering FP to B+. You should get no fuel out of the injector unless your are cranking (and it's cold enough, etc.)
Old Sep 4, 2012 | 05:37 PM
Slowey23's Avatar
try crimping or clamping a rubber section of the CSI supply hose whilst it is running if its stuck open you should hear a change
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
